Old 12-07-2015, 10:19 AM
mirovaz mirovaz is offline
Default Commit aint aligning tracks :S [solved]
Hello,
I just started using the new PT upgrade but having some big issues with the COMMIT track function.
I was mixing one song and everything started sounding out of sync at the end of the day. So today I recalled the song and Unhide the original tracks. I can see in while zooming the originals tracks and the committed one that THE TRACKS ARE OUT OF TIME AFTER COMMIT.
Example1: used the STUDER A800 from UA on every track. After commit? Out of time.
Example2: Used Brainwork ENGL guitar amp from Plugin Alliance. After commit? Out of time.
Example 3: THE BIG ONE. Used lots of plugins on the Bass. Studer A800, LA2, 1176, Ampeg ampli and limiter. After commit? OUT OF TIME.
Any help?
Cheers
MacBook Pro M1 16G RAM
OSX Big Sur 11.6
ProTools 2021.10
UA OCTO Thunderbolt, UAD Twin MK2 QUAD
Old 12-07-2015, 10:27 AM
Drew Mazurek's Avatar
Default Re: Commit aint aligning tracks :S
Works perfectly here. Used the same plugins.
www.drewmazurek.com
Old 12-07-2015, 11:07 AM
Well, not here!
Just the STUDER A800 on he track and I get this:
OSX Big Sur 11.6
ProTools 2021.10
Old 12-07-2015, 11:15 AM
no pic.
www.drewmazurek.com
Old 12-07-2015, 11:24 AM
mesaone mesaone is offline
Have you made sure Delay Compensation is turned on?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 12-07-2015, 11:27 AM
Didn't think I needed to ask because he said all was well prior to committing and with UA plugs, you'd know if delay comp wasn't on!!
Then again, this is the DUC!!
www.drewmazurek.com
Old 12-07-2015, 11:29 AM
studioj11 studioj11 is offline
Also run a bounce to disk and check import audio. If it is also off, then it is not a commit-specific issue.
Old 12-07-2015, 12:24 PM
Will do a bounce to disk and import to see what happens. Thanks for the tip.
Isn't DELAY compensation automatically on PT12? I can't find the reference to turn it on or of as in PT11/PT10.
Cheers
OSX Big Sur 11.6
ProTools 2021.10
Old 12-07-2015, 12:26 PM
I got the impression that all was not well, he said everything started sounding out of sync at the end of the day.
Old 12-07-2015, 12:28 PM
All was well before I start commit...
OSX Big Sur 11.6
ProTools 2021.10
Aligning Regions on 2 different tracks. riggi Windows 2 11-05-2011 12:47 PM
markers for aligning tracks glideman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-03-2008 12:10 AM
aligning tracks in LE to compensate for plugin dly alex obradovic Tips & Tricks 9 10-16-2003 09:22 PM
phase aligning drum tracks timmygrimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-25-2002 12:17 AM
Please help w/ aligning flown in tracks jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 07-10-2002 12:40 AM
