Old 04-13-2022, 11:39 PM
mnstudio mnstudio is offline
Default Duplicate an instrument track BUT USING THE SAME INSTRUMENT
Can't find the way to duplicate an instrument track BUT USING THE SAME INSTRUMENT, not creating an other instrument instance. I tried creating a new midi track and assigning it the same instrument instance but in this way I can't get the same originale channel strip effects settings
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Old 04-14-2022, 12:47 AM
Default Re: Duplicate an instrument track BUT USING THE SAME INSTRUMENT
I may not be following what you are trying to do. What virtual instrument? What are you trying to actually achieve?
Kind of guessing here: You want two similar VI instrument instances with two different MIDI inputs but you want to send those instruments though the same later plugin processing? Then you just route those instrument track outputs to a bus or through sends and apply that plugin processing downstream in an aux input track fed from that bus. Basically how you would do any other bus based effects processing in Pro Tools. Like how you would set up a reverb effect shared by multiple tracks.
Old 04-14-2022, 01:48 AM
Extreme Mixing Extreme Mixing is offline
If you send a new midi track to the same instrument, you will have the same FX processing on the channel strip of that instrument. If you duplicate the instrument track, as long as you tick the box that says to duplicate the sends and the inserts, you will have the same sound. As Darryl says, you should probably clarify what you are wanting to accomplish...
Steve Shepherd
Extreme Mixing
Old 04-14-2022, 04:02 AM
Actually I would get only ONE instrument instance on 2 midi tracks for trying alternative and contemporary regions which feed the same instrument
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Old 04-14-2022, 08:41 AM
Philthy Philthy is offline
From what you describe, you would have the same channel strip effects, because you would be playing the instrument on the same channel. You can't open effects on midi channels.
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 04-19-2022, 06:14 AM
In Logic you can simply Duplicate the track with the same settings (the same as duplicate track in PT), or you can duplicate the track only in Edit window, letting the same instrument instance in the mixer window (using the same button with "Opt" depressed). In this case you can decide to use alternative takes for the same instrument in some passages
I'd like to do it in the same way in PT. Is there a similar function?
See the video attached
https://www.dropbox.com/s/0s8y83jllw...nFlow.mp4?dl=0
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Old 04-19-2022, 06:59 AM
Look up “Loop Recording Multiple Takes” in the MIDI section of the Pro Tools Reference Guide. That help you? In general you should be reading that guide, it comprehensively explains all Pro Tools MIDI/VIs etc can do.
Old 04-19-2022, 09:08 AM
I'm still fuzzy on the purpose, but....Maybe a better option would be to create a MIDI track, copy the midi info from the INSTRUMENT track and assign the midi track to that same instrument plugin?
Old 04-19-2022, 01:12 PM
K Roche's Avatar
K Roche K Roche is offline
HUMM ? If I am understanding you correctly it's very simple --- JUST put your cursor over the Instrument track Name and right click > then choose "Duplicate" from the dropdown (4 th section down ). then in that Duplicate dropdown, make sure that "Inserts" is checked ... then if want to write new midi notes just delete the existing ones.. New instrument track same instrument and FX inserts ---Done
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Can one midi or instrument track, trigger, multiple instrument tracks simultaneously? jamesleonard Pro Tools 2019 5 05-24-2019 07:33 AM
AAX Instrument Plug-Ins dropping from Instrument Track stardancer AAX Plug-ins 2 09-12-2015 08:26 PM
Instrument track inactive after removing plug in OTHER than instrument pshammond Pro Tools 12 13 07-25-2015 09:19 AM
Duplicate track and instrument ModaRecords Pro Tools TDM Systems (Mac) 3 07-06-2006 02:56 PM
