Pro Tools 10.2 crashes again, and again...
OK, does anyone has the same problem, with 10.0 installed everything worked well, or maybe is better to say it is the same as Pro Tools 8, not so bad overall.
But with 10.2 , EVEN WITHOUT ANY VI's, just 20 audio tracks with maybe 15 plugins Pro Tools keep crashing on and on. It is happening with no obvious reason, select some clip, then press space (play), and it freezes there for few seconds, and then boom, crash! |
Re: Pro Tools 10.2 crashes again, and again...
Mac or Windows? what is your OS?
Maybe you need to uninstall PT10.2, then to clean up the OS etc. ... And reinstall PT10.2 (usually that's enough). If the problem persists reinstall the OS first. You must be sure that the system is really clean. PT10 normally detects plug-ins that are not updated. Courage! |
Also PT10.2 or native HD or HDX?
Have you tried any troubleshooting at all? Prefs and DBs? Emptying the plugins folder? Updating plugins?
Read: Help us Help You - READ THIS Before Posting!
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Mac OS X 10.7.4, Pro Tools 10.2 native, system is clean, fresh, maybe one month old, permissions cleaned, all drives without errors, plugins up to date, tried to delete prefs and databases, installed and uninstalled three times, still the same.
About troubleshooting, I am suffering with Pro Tools for more than 10 years, I am familiar with all I need to check and do, but still have those crashes. Everything worked well on the same system for about one month, I installed fresh system and Pro Tools 10, worked well for one month, then suddenly got again those Pro Tools issues... edit: Just made a video, a picture is worth a thousand words... http://youtu.be/Sdc5nhB9BFM |
I can't quite make out the dump screen, but it looks like crash thread 24. Could you scroll down and tells us what is thread 24? (or is it my old eyes)
If it's a plug-in... Can you a) see if there's been an update b) simply reinstall the plug-in c) see if you can live with out and if the system still crashes.
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Thread 24:
0 com.digidesign.framework.DAE 0x03e29f53 CMTHostSignalNet::WaitForWorkerChain(CPUInfo*) + 67 1 com.digidesign.framework.DAE 0x03e2a886 CMTHostSignalNet:oProcessing(CPUInfo*) + 246 2 com.digidesign.framework.DAE 0x03e2a963 CMTHostSignalNet::SecondaryThreadProcessingLoop(CP UInfo*) + 147 3 com.digidesign.framework.DAE 0x03e2aa26 CMTHostSignalNet:oThreadProcessing(int, SPlugInRTGlobals*) + 134 4 com.digidesign.framework.DAE 0x03e2b0e3 CProcessingThread::Exec() + 131 5 com.digidesign.framework.DAE 0x03e57cc2 CSimpleThread::StaticThreadProc(void*, IPSThread*) + 18 6 com.digidesign.framework.PlatformSupport 0x035d64a6 CTask_Imp::MacOSXMasterThreadProc(void*) + 142 7 libsystem_c.dylib 0x90b42ed9 _pthread_start + 335 8 libsystem_c.dylib 0x90b466de thread_start + 34 |
That one beats me, usually see plug-ins that high up....
8 Pro tools crashes in 1 day?!!? | iamnightfall | macOS | 21 | 09-26-2013 03:01 PM |
Mac OS X 10.6.2 crashes with Pro Tools 8 | NikoNewYork | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-06-2010 11:40 AM |
Pro Tools 8 Crashes | Hudson Handel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-05-2010 10:33 PM |
Pro tools 8.0 crashes out of no where | chrono4548 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 02-03-2009 11:45 AM |
Pro Tools CRASHES my PC | XyberICE | Digidesign Hardware & Software | 4 | 05-07-2005 03:44 PM |
