Old 01-14-2011, 10:44 PM
GW GW is offline
Default Fader knobs flying all over the place...
This is a Q for the Euphonix support!
What is your official recommendation about the knobs flying off the MC Control v. 2 unit (as have been stated in several threads before).
1) Will they be replaced with a minor construction change (like some toa and heel in the plastic)?
2) Do you officially recommend us users to use some kind of superglue?
For a unit with this kind of pricetag, this is really a childhood disease.
For any one to answer to...
The 6 programmable knobs on the MC Transport have yellow lights so you can see if they are "on" - do the 12 programmable knobs on the MC Control have none (or is it just some kind of fuse on my unit)?
(If "No" - is there no lights build in or is it just software programming?)
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Old 01-16-2011, 11:07 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Fader knobs flying all over the place...
I haven't seen this with my unit.
Could you put some cotton inside the knob hole to make a better fit? That may give a little more tension to the connection.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
flying fader caps solution therecordinghouse Artist Series 0 06-11-2012 06:58 AM
Connect fader knobs? Codo Pro Tools TDM Systems (Mac) 6 10-14-2011 04:07 PM
PC main unit w/ clicky knobs want smooth knobs Brandonx1 ProControl, Control|24, Command|8 6 10-20-2008 11:34 AM
Digi 002 - flying fader issue in flip mode bluemanna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-14-2003 01:54 AM
Digi002- New Fader Knobs & Hard copy of Manual CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-15-2003 06:34 AM
