Creative Collection not installed
Just jumped up to 8.0 and came across this error while installing (all 3 times)
Protools Creative Collection error - 2147213312 None of the new instruments are available....and the original xPand is also gone along with the full version of Structure Any ideas ??
003r/i7-930/LE 8.0.1 cs2 on xp |
Re: Creative Collection not installed
sounds like a good time to restore your machine back to before you installed 8 and i would install 8 w/o the creative collection, get it running then install the creative collection seperatly.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Thanks for the tip , I'll give it a try...glad I use Acronis
Rolled back, re-installed, same problem(s).......
1. Elastic Audio will not install as of this message: Pro Tools LE: ProToolsLE.exe-Entry point not found: The procedure entry point ?Destroy@RadiusEngine@iZ Radius_v1Z@@SAXPAU12@@Z could not be located in the dynamic link library iZotope_Radius_Win32.dll 2. ProTools Creative Collection error-2147213312 None of the new inst. were installed, and my full version of Structure disappeared. 3. Another error message appeared near the end of installation: 'This app has failed to start because HWC.dll was not found. Re-installing may fix this' Not sure what that one's in regard to. And of course the moogerfooger fiasco...not a big deal. Digi said they will be fixing that one. Despite all the errors, I did get 8 installed, and all the plugs I thought I would have problems with are just fine...Waves, NI ..etc. Just no new instruments, no Structure, no Elastic Audio. I'm downloading it again to rule out a corrupted zip file , and if that doesn't work I'll wait till I can get the install DVD. Oh well....back to 7.4 for now.......gotta' love Acronis
Another tip: If the files DO extract properly, burn these files directly to a DVD and install from there. This will ensure that your PT8 Installer files remain intact and correctly stuctured. Good luck!
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2 AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM www.wolfskinrecords.com www.voodoopilot.com |
When I get home I'll download WinZip and try again.
Am I missing something here...spent 10 hours downloading so far with 2 corrupt zip files..
Did you try the Windows Unzip application yet?
BTW, where are you in TGWN? If you're anywhere near Toronto I have the complete download of 8.0 (including MP3 Option, Loops, Melodyne Essential, BFD Lite, Torq LE and the v2Tech Utility [which is not performing properly, Delete Preferences works, Delete Digidatabases does not]) that you're welcome to take a copy of. I'm only offering this because I know you've already paid for it or you wouldn't have been able to download it. Cheers,
I've got to take off to rehearsal right now...I'll try when I get back. Edmonton ( and it's fricken' COLD right now}
Good luck!
Air Creative Collection | Caatalyst | Pro Tools 11 | 2 | 07-16-2013 12:33 PM |
AIR Creative Collection | lownotesinc | macOS | 7 | 05-19-2013 04:49 AM |
Can't Get Creative Collection Installed | Digi_D | Pro Tools M-Powered (Win) | 6 | 06-09-2010 10:58 PM |
After Creative Collection is Installed PTLE8 Freezes Causing Reboot | MitchM2006 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-17-2009 01:22 PM |
Creative Collection | stillwarm | Virtual Instruments | 14 | 08-01-2009 03:04 PM |
