Old 11-08-2016, 05:30 PM
ergalthema ergalthema is offline
Default Best workflow to match new cut of video?
I know a few ways to get the end result, but none of them are totally seamless.
I've created some audio work for a short film. There is no slate, 2-pop, etc. The editor sends a new version, but there are a couple edits changes that affect the timing.
How would you shift large chunks of the project (including markers) to match the edits?
Mid-2014 15" MBP Retina 2.8GHz Intel Core i7, 16GB DDR3, OSX 10.10.5, PT11.3.1 003 Rack Factory.
Old 11-08-2016, 09:29 PM
minister's Avatar
minister minister is offline
Default Re: Best workflow to match new cut of video?
http://www.thecargocult.nz/conformalizer.shtml
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 11-09-2016, 06:42 AM
Cheesehead Cheesehead is offline
Tom is right, Conformaliser is the easiest way.
But,
If you only have a couple of changes.
Make a copy of your session so you can get back what you have if it messes up.
Put both old and new video tracks in PT with their guide tracks for reference.
Do all the following in frame grid.
Put a marker where the top of the section you want to move is and another where it needs to end up.
hide your new video + audio refs or they will get cut too.
Click in the timecode track to get a cursor across all tracks at the point you need to change and make a cut. Holding shift, click in the markers lane to select that also, (it doesn't automatically select with all the other tracks). Then go to the end of your selection and holding shift click in the timecode track there. This could be the end of the film if you're adding new material.
Then either delete the chunk you have highlighted and nudge back the later stuff or extract with the X key, type in your new timecode or click your marker and paste.
Remember to do all the above in frame grid mode and nudge to fine tune.
If you have an audio ref with the new quicktime, play that against your newly moved chunk to check sync.
Good luck.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 11-11-2016, 07:47 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Originally Posted by minister View Post
Tom,
That entails getting a valid CMX3600 EDL, of both new and old cuts, not easy to get lately!!
IMDB
Old 11-12-2016, 12:44 PM
The Cargo Cult's Avatar
The Cargo Cult The Cargo Cult is offline
The Cargo Cult
Why?
EDLs are extremely easy to export and it takes all of 10sec to do it.
if it's a big project you might find the editor does a bit of tidy-up work before exporting EDLs, but the actual export is child's play.
And if your picture editor really, really can't find the menu item to export an EDL, let me know. There might be something new on the way to help out....
Justin
Old 11-12-2016, 03:11 PM
Originally Posted by The Cargo Cult View Post
Why?
Justin
Justin,
I agree with you!!!
Been using Conformalizer going on 8 years now. You remember me, you helped me out with the DF bugs.
5 episodes of each Top Chef season are made 55 minutes, then cut down to the standard 44:30
166 edits on todays episode!
It's a fantastic tool. 25 minutes to conform at the slow speed setting. Paid for itself day one.
Creating EDLs in MC 8 is easier than ever. I can even do it. (Child's play)
But recently, I have had to do these by hand/eye/ear.
TV picture editors can't be bothered creating EDLs, nor tidying up. (You should see my AAFs!!)
AEs are getting stupid. They have no hindsight on creating a single video track, by removing the graphics, lower thirds, stills, etc. Dropping the pertinent parts to video track 1.
Yes, I need to use a single video track as an EDL.
These shows have 6 video tracks at times.
Then having them, do it the same way between the supersize, and cut down, yeah right.
Then they are cut 23.98 video, with a 29.97DF timeline. Having them revert the timeline to 23.98, is a lesson in futility.
Online edits 23.98 and so do I then gets converted 29,97DF on the Media Composer.
IMDB
Old 11-13-2016, 06:08 AM
Postman Postman is offline
+1 Conformalizer!
Very recently I was strategizing with a "post supervisor" in anticipation of recuts of a few hours that were either already mixed or were in progress. The guy was baffled the anyone would want an EDL, saying he hadn't seen one in years. Then he said he didn't think his Avid's could create one anymore, which I assured he they can, then he insisted on reading Conformalizer's manual to see if I knew what I was talking about, after which he poked fun at the program and workflow that "looks so 90's". Finally the guy said he didn't want to introduce a new element into his AE's duties and suggested I should conform by hand.
I just charged an hourly overage to conform by hand.
This guy is "unenlightened" but he's not the only one.
system specs in profile
Old 11-13-2016, 12:06 PM
Scott G Scott G is offline
I would love to give Conformalizer! a go as it's always good to support local business. However we run PCs. Anyone have a suggestion for PC?
Thanks
Scott
Scott
Auckland New Zealand
PT2022.5 Focusright RedNET 8Pre, RedNET R1
Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit
Old 11-13-2016, 05:23 PM
Buy an old mac? It sounds preposterous but would get the job done. Old computers are cheap but stalwart.
Conform really ought to be built into Pro Tools, by the people who bring us Media Composer. Why oh why do they not bother?
Old 11-14-2016, 01:55 AM
smurfyou smurfyou is offline
An EDL is such a simple thing to ask for, I don't understand why some people refuse. We're so difficult because we need a standard file that takes 10 seconds to export? Color grading still uses EDL and XML so it's not that out of the ordinary.
Nevertheless, Conformalizer and EdiLoad are such great tools that save many hours and headaches.
I agree, reconform should be built in to PT but we've been saying that for ages. It would be trivial for Avid, especially to facilitate between MC. But it's one of many baffling shortcomings in the Avid Everywhere world....
~Will
HTML code is On
New Pro Tools Workflow Video IntelDoc General Discussion 0 03-23-2013 11:04 PM
Auto Match Pull Factors & 25fps to 24fps workflow tj_davies Post - Surround - Video 4 03-05-2008 09:26 AM
Video, Compositing then Audio Workflow di0nysus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-28-2008 11:11 AM
Film/Video Workflow smack5099 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-18-2007 06:48 PM
High Def Video Project Workflow Rick Sanchez Post - Surround - Video 0 08-23-2005 08:59 AM
