SampleCell TDM nubus
Wondering if anyone can tell me what the last version of protools to work with sampleCell TDM on a nubus system was? I have a non TDM SampleCell in an expansion chassis (using analog outs) that works fine. However I can't get the ( just purchased) SC II TDM to work. The inputs don't show up in the Mixer. OMS does recognize the two cards. Checked all the archives. Nothing I could use. Config: OS 8.6 ProTools 4.3 2 disc I/O 6 farm 1 SC II 1 SC II TDM 24 bit mixer If anyone can help me I would appreciate it. Thanks in advance. David |
Re: SampleCell TDM nubus
Are you sure you connected the TDM cable between the Samplecell card and your core or farm cards?
Andre |
Yes. 2 i/o's, 6 farms and then a SampleCell TDM. All connected via 12 node ribbon. Everything works fine, but I understand that SC inputs should show in mixer (they don't). I trashed digiSetup, Dae pref. , protools 4.3 pref. Seems like OMS is working fine, since I can trigger sounds with both SC cards but only via analog outputs. Is there any additional software that needs to be installed so that the inputs appear in the mixer?
Thanks, David |
I haven't used a Samplecell card yet (I have one one the way), but you may have to go into the I/O setup page and define the SC inputs. Then you'll likely be able to assign those inputs to an aux track.
Andre |
*stupid question*
Did you install the SC TDM plug-in (in the TDM plugin folder)? jr
--Jeremy |
Andre,
Thats what I thought, but SampleCell is greyed out in I/o lables. Ican't figure it out, but I am still trying. David |
The last version of Pro Tools that supported Nubus Hardware was 4.2. Also, the 24-bit mixer is untested and unsupported on Nubus hardware (as Brent said).
Once you have a supported configuration, make sure that the SampleCell Plug-In is in your plug-ins folder, as SAMPLEHEADS suggested. Steve |
*stupid question*
Did you install the SC TDM plug-in (in the TDM plugin folder)? Boy am I glad you asked that stupid question because NO I had no idea..well I had an idea but heck Iv'e only been using protools since 1995! [img]images/icons/smile.gif[/img] Anyway any idea where I can get this plugin? The card came with four floppies, not a plugin in sight. Thanks, David |
I think it's on 1 of those floppy's or on your PT installer disk (as far as I can remember).
I just installed a Samplecell II nubus in my expansion chassis and am having the exact same problem. The Samplecell plug-in (ver. 1.1.1) is in the tdm folder. Does the DAE and DigiINIT have to be exactly ver 3.1?
SOS JC! SampleCell NuBus Problem | tunes | Digidesign Hardware & Software | 5 | 02-19-2004 03:34 PM |
Nubus PT 5.0 and Samplecell anyone? | Tex Tiles | Pro Tools TDM Systems (Mac) | 1 | 11-27-2001 01:01 PM |
SampleCell II NuBus | TT | Pro Tools TDM Systems (Mac) | 0 | 06-11-2000 09:00 AM |
SampleCell Nubus | alkooloid | Digidesign Hardware & Software | 0 | 09-25-1999 05:22 PM |
WTB: Nubus Samplecell II | Rich Breen | Digidesign Hardware & Software | 2 | 10-19-1998 12:14 AM |
