2018.4 + Windows 7: Won't even let me install :(
2018.3 installs, and I was able to use it for a day, but after a couple days, it would no longer launch, so I went back to 2018.1. Today I had some time to install 2018.4, bit it refuses to install and gives the error message: The operating system is not adeaute for running Avid Pro Tools.
"Not supported", I can handle, but to not let us install at all, is that really necessary? I'm only 1/4 of the way through my subscription, so this is bad news. Another tidbit- Windows 10 is not compatible with my Aurora 16 + AES16e setup. Caused tons of problems with settings changing automatically which caused my 32-channel system to switch to a 16-channel system so half of the channels wouldn't pass audio. Works perfect on Win 7, so I guess my system is EOL. Very disappointing. |
Re: 2018.4 + Windows 7: Won't even let me install :(
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
I got round this problem by not doing a clean install. Usually I remove the previous version but this time installed 2018.4 over 2018.3. Now it runs with no problems. It will be a case of updating the OS in the near future though.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
^^^+1
I have 18.4 running on three windows 7 machines with no issues. They are all Intel processors. Don't know if that makes a difference
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Interesting. I’ve never tried to install a new version that way. 64GTOBOY, I’m guessing you installed yours the same way? I will give that a shot. The Win8 suggestion is good as well. Will research that. Thanks everyone!
Ok, now I'm getting angry. I'm now having the same problem with 2018.1 where it will not launch. I was just using the damn thing last night. What on earth is causing Pro Tools to not launch at all? Might have to hit up support this morning.
Well, the compatability notes for 2018.1 and up do show that Win 7 is not supported.
If you have access to 12.x you can update from there. I am semi -sure I updated all mine using app manager. I download the install files just to have backups, which I have been doing since 12.1, but i don't usually update the way you are "supposed" to (uninstall, etc). I generally start with the smallest laptop and when it updates correctly i do the bigger laptop , then the desktop last. Advise you to"Trasher" pref.s first. I'd be willing to bet that at this point you have a lot of extraneous s&%t in caches that are causing issues. As for the whole "not supported" that really just means that avid is not going to bother testing on win7 anymore, but lets face it 18.1 is really just 12.93 under the hood. And win10 may have changed it's UI from 7 but the underlying code, well it ain't that different.
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Thanks for the tips guys. I'm in the middle of a few projects right now and haven't tried to mess with it again. Digi support also suggested trashing prefs & databases which got my 2018.1 launching again. Will try the 2018.3->2018.4 install when I'm more caught up.
Lost HEAT in 2018 Install | zeeman | Pro Tools 2018 | 14 | 11-23-2019 12:35 PM |
2018 Install Issues...I'm DOA | LightWing | Pro Tools 2018 | 10 | 04-06-2018 08:52 AM |
2018 | install plugin path? | chip_nelson | Getting Started | 8 | 03-31-2018 04:37 AM |
Pro Tools 2018 install | paddyrfc | Pro Tools 2018 | 10 | 03-24-2018 04:42 AM |
PT 2018 all user shortcuts erased on install | Cheesehead | Avid S1, S3, Dock and Control App | 4 | 01-30-2018 01:59 PM |
