Old 12-23-2012, 04:11 PM
FERGY FERGY is offline
Default Re: 10.3.2 Heal separation not working. BUG?
I guess when I say silence, I mean space. The blank space between the regions is still there when I consolidate them. I thought it would put those 2 regions together in the same way 'heal separation' is supposed to. And if I try to correct the timing by moving either part it just doesn't sync exactly. There's still a gap. Anyway thanks for your help.
Old 12-23-2012, 04:53 PM
Rail Jon Rogut Rail Jon Rogut is offline
To create separate regions with the space between use Gain with no gain change and select region by region as the modus - it's a bug which is convenient
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-24-2012, 10:40 AM
Rail
Thanks.
And will that help me join both the regions together?
Pro Tools 10.3.3 not working with MAC 10.7.5 [solved] tchambeau Pro Tools 10 9 02-13-2013 02:17 PM
Heal Separation gone? Reckless Erik Pro Tools TDM Systems (Mac) 5 12-17-2009 06:33 AM
Low Latency Not Working! Has Anyone Solved This?? orangepopsongs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-24-2007 11:56 PM
Heal Separation process question Paul Alvarez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-16-2006 04:40 AM
Digi wont consolidate or heal separation surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-28-2001 02:34 PM
