Old 03-19-2011, 02:55 PM
theshizon theshizon is offline
Default How do I change pitch over time?
hi guys.
Ive just been scratching my brain here trying to figure out how to change the pitch over time on a stuttering guitar part.
I chopped it up into 32nd notes for 1 whole bar (a 32nd of sound and a 32nd of silence inbetween)
I want to increase the pitch 1 semi-tone on every 32nd note so its getting progressively higher in pitch over time
I know I can do it with each individual slice but that is time consuming and I was wondering if anyone knew a trick with elastic audio or something?
thanks alot
shaun
Old 03-19-2011, 05:18 PM
mhuang mhuang is offline
Default Re: How do I change pitch over time?
sounds like you want a pitch bending effect.
unfortunately PT doesn't come with any plugins or any easy native way to pitch bend.
I've used waves' soundshifter plugins with pretty good results.
Old 03-19-2011, 07:08 PM
Originally Posted by theshizon View Post
hi guys.
thanks alot
shaun
Try Elastic Audio's Vari-Speed algorithm. I've never used it, but I think it does what are looking for, like a recording speeding up or slowing down? Serato Pitch 'n Time is another option where you could highlight the entire section, shift up a half-step, then highlight all but the first region and repeat. Keep selecting 1 less region each time toll you reach the last region to shift(PnT works as an AudioSuite plugin only). Check out the Serato website to see if they offer a demo. I have X-Form and think Serato is much better sounding.
Old 03-19-2011, 10:59 PM
TOM@METRO's Avatar
Here is another vote for Pitch 'n Time Pro for this.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-19-2011, 11:04 PM
Tweakhead Tweakhead is offline
1. Instanciate the basic Digi Pitch plug-in on your track.
2. Click on the Auto button in the plug-in (next to presets)
3. Choose "Coarse Shift", click Add. OK
4. In your Edit Window, instead of Waveform view the Pitch/Coarse Shift automation lane.
5. Set your grid to 32nd notes. (or 16th notes if you only want the change on your actual non-muted audio regions)
6. With the pencil "line" tool, draw a line from your starting pitch to your end pitch.
Once you release the tool it should show a stepped pitch change. Voila, you're done.
Hope that helps.
Old 03-21-2011, 04:00 PM
Hope that helps.
you can't use pitch shift plugins as an insert on PT.
Old 03-21-2011, 04:06 PM
Wow. So because you don't have a TDM system - it can't be done?
OK, here it is s - l - o - w - l - y
Step 1. In the Mix Window go to select a plug-in
Step 2. TDM Plug-Ins
Step 3. Pitch
Step 4. Follow the previous directions.
Old 03-22-2011, 12:00 AM
Dingo90 Dingo90 is offline
damn dude, relax.
you didn't exactly make it clear that it only works for HD system in your original steps.
guess you picked the right username.
Old 03-22-2011, 12:21 AM
so, apparently, did you.
Old 03-22-2011, 12:30 AM
touche
[IMG] code is Off
BIG BUG: Wrong playlist calculations when using AS Pitch 'n Time or Avid Time Shift Franco1967 Pro Tools 11 1 01-25-2014 11:31 AM
Pitch & time change jonslaten Pro Tools TDM Systems (Mac) 4 03-26-2009 02:21 PM
Is time compression supposed to change pitch...? celdry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-02-2003 12:28 PM
*** Time Stretch/Squeeze & Pitch Change *** Dan Clark Tips & Tricks 5 10-09-2002 04:17 PM
Tempo change without pitch change for audio layman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-16-2002 07:14 PM
