HELP -9093
Im getting a 9093 error in 24 bit sessions whenever i start to use fast forward or rewind on the transport. The error message suggests it's a buffer issue however i've tried all buffer settings. Doesn't happen in 16 bit sessions!! Somebody help....
Re: HELP -9093
-The driver for the IDE controller card is most likely the problem. Switch to the standard Microsoft driver.
-If you are using a SCSI card, then set the transfer rate set to 20Mb sec. Brent |
Re: HELP -9093
Having probs changing IDE controller!! I have an ASUS CUSL2-C M/B running the Intel Ultra ATA Controller. Is this a problem?
The rest of the specs are: PIII 850 133mhz 128mb 10Gb Seagate H/Drive 20Gb Western Digital 7200 rpm H/Drive Matrox 400 16mb VGA |
Re: HELP -9093
How to install the Generic IDE Controller from the Win98 CD-ROM:
-Insert the Win98 SE CD-ROM -Open the Control Panels>System>Device Manger tab -Expand the Hard disk controllers list -Highlight the IDE Controller device, click “Properties” -Click the Driver tab and then the “Update Driver” button -In the Update Device Driver Wizard, enable “Search for a better driver...” and click “Next” -Enable the CD-ROM and click “Next” -Enable “Install one of the other drivers” and click “View List Brent |
Help with PT8 and 9093 9094 | KenOnBass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-18-2009 09:24 AM |
Error -9093! | Fenace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-25-2005 02:05 PM |
9093 !!!!!!!! - IRQ? | hitwriter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-21-2005 08:24 PM |
9093 HELL | pmh3r | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-27-2001 08:14 PM |
dma and 9093 | reeve oliver | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-27-2000 08:07 PM |
