Old 01-23-2023, 12:51 PM
beanbagjimmy beanbagjimmy is offline
Default macOS Ventura + S4 Programmed Soft Keys don't execute 'KEY' commands
Hi everyone,
Mac Studio
macOS Ventura
Pro Tools 2022.12
Avid S4 (2022.9.0.44)
We have an issue where Soft Keys on the main module which use the function 'KEY' (for example, 'V' for paste) do not work. On the other hand, Soft Keys which are configured using the 'EUCON' function for the 'Paste' command will work.
Has anyone else encountered this issue? Anyone know if there's a solution other than rolling back to a previous OS?
Thank you very much.
Old 01-23-2023, 02:21 PM
reichman's Avatar
reichman reichman is offline
Default Re: macOS Ventura + S4 Programmed Soft Keys don't execute 'KEY' commands
It's probably this issue:
https://duc.avid.com/showthread.php?t=419580&page=2
Scroll to the bottom for gory details. Good luck.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 01-24-2023, 10:41 AM
Thanks so much, Nathaniel! It fixed the issue.
macOS Ventura 13.0 - Anyone tried it (or a beta)? alzakent Pro Tools 50 05-19-2023 06:31 AM
Pro Tools Compatibility with macOS 13 Ventura newcens Pro Tools 14 02-08-2023 01:18 PM
MacOS Ventura LDS macOS 7 09-15-2022 02:30 PM
Eucontrol - Soft key commands fail on MacOS and WinOS koo_koo_bonkers Avid S1, S3, Dock and Control App 0 03-25-2020 01:16 PM
Soft Keys No Longer Execute Keystrokes aadvance Avid S1, S3, Dock and Control App 8 11-11-2019 02:43 PM
