Old 06-06-2017, 08:26 PM
Jacob Champoux Jacob Champoux is offline
Default Focusrite Scarlett 18i20 distorting sound with PT
Hey all! I have a Focusrite Scarlett 18i20 (1st Gen.) that I bought about a year ago. It worked with Pro Tools perfectly, started on version 12.5, and now I've had nothing but problems (currently running PT 12.7.1) After a few minutes, the Scarlett makes this distorted audio sound. And if it's not that, it's clicks and pops. I've tried uninstalling/reinstalling PT, and even back to version 12.5. Nothing. Does the USB cable or port have anything to do with this? I usually have to close PT and start it up again. I don't really know if PT is the culprit as sometimes the distortion comes while I'm in my web browser. I've disabled my system sounds and made my internal sound card the default playback and recording device. All with no fix. Would rolling back to a previous version of PT help at all? I was fine during the 12.5 - 12.7.0 era.
Thanks in advance,
Jacob Champoux
Windows 10 Home 64 bit
PC: Asus F555U, i7-6500U 2.5Ghz, 8gb RAM, 480gb SSD, 1TB HDD
Pro Tools 12.7.1 (Standard)
Old 06-06-2017, 10:55 PM
Playback engine buffer size? Session sample rate?
Driver version?
Clocking internally or externally?
System fully optimized?
Direct connected to computer USB or using a hub?
Tried other troubleshooting like trashing prefs?
Moving all plugin files out of the plugin folder?
Old 06-06-2017, 11:53 PM
Jacksonland Jacksonland is offline
Default Re: Focusrite Scarlett 18i20 distorting sound with PT
I agree with the above, especially:
"Playback engine buffer size? Session sample rate?"
"Clocking internally or externally?"
MPEG, CAS, ATAS, NARAS
Izotope Artist
27" iMac Retina 5K, 4 GHz i7, 40 GB RAM, 4 GB GPU
PreSonus Faderport 16 and PreSonus Faderport 8
4 monitors - Neyrinck V-Control Pro
Focusrite Clarett 8PreX and Octopre Dynamic 96K 32bit
Vintage Neve 1073 and Sunset Sound Tutti Mic Pres
Old 06-07-2017, 10:38 AM
The Weed's Avatar
The Weed The Weed is offline
Have you updated the Focusrite driver recently. At least on Windows, Focusrite's drivers have not been stellar. One of the reasons I went RME when I moved on from my 002 Rack.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 06-07-2017, 12:37 PM
and, set Windows to NOT use the Scarlett as its default playback device
Old 06-07-2017, 07:50 PM
Playback engine buffer size? 256 Samples
Session sample rate? 44.1k
Driver version? 2.5.1
Clocking internally or externally? Internally
System fully optimized? Followed both Avid and
Focusrtie Optimizations
Oddly enough, as soon as I posted the initial question, my rig started working again. I deleted the beta driver I was using (for a day) and reinstalled the latest Focusrite driver with MixControl. I also moved the interface's usb male end from the powered hub I was using and plugged it into a free port. Ever since, Pro Tools and the Scarlett have been working perfectly. I was able to track multichannel drums for a band all day. I'm glad there's a community of helpful individuals like you all. Thanks!
Until next time,
Jacob
Protools 12.4 Freezes when Idle on Win7 , Focusrite Scarlett 18i20 USB digi98 Windows 4 03-17-2016 05:43 AM
Focusrite scarlett 18i20 madselhoff Third Party Interfaces 6 01-25-2016 04:45 AM
Pro Tools 11 with Focusrite Scarlett 18i20? hermonmusic Third Party Interfaces 24 06-27-2015 08:53 AM
Focusrite Scarlett 18i20 ProTools crash. BurtonTrucking Third Party Interfaces 7 04-17-2014 11:30 AM
Eleven Rack + Focusrite Scarlett 18i20 eboyer Eleven Rack 2 03-16-2014 09:51 AM
