#31
Re: Bigger is Better, or is it? Monitors.......
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
#32
No. Bigger is not better and placement is very important.
Make sure your monitor is not so far back that it reflects the signal from your speakers back to you, you don't want that, if you can either place them below or above the monitors out of the way of reflections. If you place the monitor close to you, in front of the speakers, be aware of edge refraction. As a rule, I make sure all screen monitors are a max of 22'' or less the 22''.
#33
I'm more worried about the big console than the edge of my monitors. I've had my mix room analysed and tuned and the monitor had no impact in the overall sound.
Sent from my SM-G935V using Tapatalk |
#34
You mean reflections from the desk itself? Off the surface of the desk? Nice space you have there my friend....
#35
When I put in the new S6 I'm redoing the front wall for soffit mounted Adam main monitoring. Sent from my SM-G935V using Tapatalk |
#36
I have my current monitor on a VESA extension, I can have it all the way back to the wall, or as close as 6" from my face if I want.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
#37
Re: DP\HDMI splitter (KVM)
I use a pair of Dell 27 via DP in my home studio (2560x1440). Since I also work from home I have to be able to switch from my HP laptop to my mac pro. As unplugging cables is a PITA I did the search for an inexpensive KVM and I found the VellBox which is cheap on amazon. Even has a remote if you want to place it far away. At 55 buck on amazon its a steal. Thought I would share. Its construction is all metal and it also has USB and headphone ports etc though I dont use that. Good if you want to be able to easily switch displays etc. Peter
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
Bigger HDD's | JuanPC | General Discussion | 1 | 01-08-2016 06:45 AM |
Bigger HD? | Mac88s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-27-2008 04:28 PM |
Dual 17" or 19" Monitors? Is Bigger Better? | a2zproductions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 02-21-2005 01:18 AM |
OT: Getting My Kick Bigger | Bobby Peru | Pro Tools TDM Systems (Mac) | 4 | 02-04-2003 09:04 AM |
Is bigger better? (Speaker Monitors) | steals | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-25-2002 10:21 PM |
