#41
Re: no side chain delay compensation for HD Native users
The more I think about it too... using Commit instead of Freeze might be a better move for creating a "plugin-less" and/or "delay-inducing-less" duplicate trigger track, assuming Kregan's theory is correct. That way, you might have better session backward compatibility across different versions of PT and your trigger track will travel better bc it's simply printed audio. Still need to test this...
Mac Pro 3.5GHz 6-core (6.1, "trash can") Monterey 12.7.3 32 GB RAM Pro Tools|Ultimate 2023.12 HD Native Thunderbolt HD I/O 16x16 Analog |
#42
Yep that should be included with HDN
#43
What about if you disable adc on the track and simply slip it in time (to manually compensate latency)...
Can you please send yourself over fiber to go spam some other forum? Darryl Ramm |
#44
Almost a year since this thread opened, not a single word from anyone connected with Avid about it. Not a "hey, we heard, we may get around to it, we may not", not a, "it's a technical issue and only HDX can handle it," (not that that would make any sense unless their entire delay compensation scheme is so insane that THEY don't even know how it works, and as far as I know is compensated for in Studio One), just complete and utter silence. Like my god, if I was a perspective customer and I looked at this site, I'd run away as fast as possible. We've got users complaining left and right about how the company treats us, users posting issue after issue and the only people offering assistance are their fellow users, and no form of representative of the company can be found (this isn't intended as a slight to our wonderful mods, just that they aren't, for instance, customer relations employees of Avid. Do those positions exist at Avid?). How the hell in the course of the last year and a half has no one in the Avid executive structure said, "guys, I think maybe we should do something before we've pissed them ALL off"? Literally having someone spend a day just going through the forum and letting users know that Avid is listening would be a huge start. Even when you specifically ask for some basic clarification on their product, no matter what you do you will not get a reply from anyone at Avid, at least not in the multiple attempts I've made.
I feel like I'm in an abusive relationship, I've spent waaaaaaay too much time learning Pro Tools to want to switch, and having done a lot of research, I don't see a product that holds the promise of Pro Tools. Particularly Presonus knows what's up in terms of communication with their customers. But Studio One isn't Pro Tools. Unfortunately, a lot of the time neither is Pro Tools, cause you're dealing with some nonsense or having to figure out some workaround to get something done that they've decided is a differentiating feature for HD only, for now, until they decide it isn't. Come on Avid, you can do better than this. A lot better.
C. Shawn Eib Owner, Sounds Like Audio, LLC facebook.com/soundslikeaudio [email protected] Providing recording, mixing, and post-production audio services, as well as consultation and both on-site and remote pro audio tech support. Shoot us an email for more info! |
#45
All of this is great stuff
#46
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD) MacMini (Core i7 Quad@2,3GHz RAM16GB SSD) PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP) PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP) PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD) PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD) RME UFX (USB2 with MM and Firewire with MBP) + Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1 |
#47
This is 2017 and it is outrageous that this is an HDX-only feature. I can't "Brauerize" my mix properly... To break something only with the intent to sell expensive hardware is something that makes all customers angry.
FROM THE PRO TOOLS 12.7 manual: "Delay Compensation for Side- Chains (HDX Systems Only) HDX systems let you automatically compensate for signal delays in side-chain processing. In some cases, you may want to disable automatic delay compensation for side-chains (such as for sessions created on previous versions of Pro Tools where you have manually compensated for side-chain delays). To enable (or disable) automatic delay compensation for side-chains: 1 Choose Setup > Preferences. 2 Click the Operation tab. 3 Select (or deselect) the Compensate Side Chains option. 4 Click OK." |
#48
Yes seriously, why aren't side chains compensated in all versions of Pro Tools. They are unusable for most purposes otherwise. It actually makes less sense it works on HDX, given the additional complexities of DSP. Come on Avid please compensate the side chains!
#49
Perhaps they can't do it.
#50
side chain delay comp solved (Non-HD) | Macsearcher | Pro Tools 11 | 1 | 02-04-2015 12:40 PM |
Delay Comp and Side Chain Issue | jimmyzk | macOS | 15 | 02-11-2013 04:48 PM |
Delay Compensation using Side Chain | Oblivion777 | Pro Tools 10 | 4 | 10-11-2012 01:22 PM |
Delay comp and Side Chain Issue | jimmyzk | macOS | 2 | 10-01-2012 02:46 AM |
