Creating an AAF or OMF in Pro Tools for Avid Editor
I have a couple of questions about creating an AAF/OMF in Protools.
1. will omf maintain all my routing/bussing 2. Will that routing translate into AVID 3. Is there a size limit (my session is rather larger, over 4gigs) 4. What is the max handle size
Windows XP Pentium(R) 4 CPU 3.2GHz 3GB of Ram 78Digi002 w/ DV Toolkit |
Re: Creating an AAF or OMF in Pro Tools for Avid Editor
I could be wrong but I think it's a one way street. You can't import OMF / AAF in FCP and Avid, only export.
1. NO
2. NO 3. 2 GB is the limit for embedded media. You can use referenced media to overcome this limit or split tracks to multiple sequences. 4. Only need handles with embedded, not sure about the limit when exporting from Pro Tools. Avid can import OMF/AAF, but they are limited in track count, so something to consider if it is a large session in terms of tracks. |
There is also the issue of them only being able to edit audio on frame boundaries, which means any edits you do will get moved to the nearest frame boundary.
You have to check the box that says "Enforce Avid Compatibility" to make sure you edits are on the frame, if not, I believe the avid will throw errors when opening the sequence, but it has been a few years since I sent something that way (usually the AAFs come to me) |
Us too, still on 4.0.5
Thanks for the quick replies. I figured the bussing wouldn't translate to AVID but I guy can dream can't he. Post "lock" and delivery, a show needs to be opened and re-edited. I was hoping I could just give my mix via omf cut out the reconform process. It is obliviously a pipe dream without Virtual Katy...
Unable to locate Avid hardware. Avid Pro Tools SE 8.0.3 (M-Audio KeyStudio 49) | azndisast3r | Pro Tools SE and Essential (Win) | 3 | 09-21-2013 02:31 PM |
Will (Avid/M-Audio) Pro Tools MP 9 support Avid Vocal Studio: Producer USB Microphone | XDosShane | Windows | 0 | 02-04-2012 09:17 PM |
Avid 2trk editor | Audiofarm | Pro Tools TDM Systems (Mac) | 1 | 03-24-2011 12:01 PM |
Do you prefer OMF or AAF from an Avid editor | cananball | Post - Surround - Video | 6 | 09-28-2010 06:02 PM |
Avid editor - needs trim like function | Simpson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-10-2005 08:19 PM |
