Can I control my 11R from two midi contollers?
One is Pro Tools and the other would be a Behringer midi controller. Right now my rig is controlled from PT midi sequencer, but I would like to have parallel control from a pedalboard. Can I merge two midi signal into one and feed this to 11R?
Re: Can I control my 11R from two midi contollers?
Sure. Does the FCB-1010 have a MIDI input and a MIDI thru output? If it does, just run the PT MIDI out to the FCB's MIDI in, and the FCB's MIDI thru to the 11R's MIDI in.
You may have some glitches with the MIDI thru on the FCB unless you have the UNO ROM. |
or if your other midi device can be plugged in via USB, that would work too. I plug in a control board and keyboard with fader controls via USB, to control PT, and the FCB right into the 11R via Midi cables.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I know this to be true because I found out the hard way that the GR-20 and the 11R share some MIDI CC messages. I ran the GR in to the FCB1010 and then from there to the 11R and when I used the patch change buttons on the GK pickup it changed the GR20 and 11R patches. A serious WTF!?!?!? moment until I realized what was happening.
just make sure each devices are receiving on a different channel, and they won't get confused. Of course your controller has to be able to send multiple messages on different channels as well. With this you can control many devices with ONE controller. But yeah, with MIDI thru you can use multiple controllers with the 11R.
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM Pro Tools 10.0.0 Ableton Live 8.2.1 RME Fireface 800 Eleven Rack |
2 Midi Contollers in Protools 9 | Lolercat | macOS | 0 | 04-03-2011 11:04 AM |
Pro Control mapping for midi control? | michael c | ProControl, Control|24, Command|8 | 0 | 04-06-2007 12:36 PM |
Evolution U-Control midi control surface | eddie v | MIDI | 0 | 03-22-2004 03:53 PM |
MIDI Machine Control out of control | zenbarai | Post - Surround - Video | 3 | 04-19-2002 07:08 AM |
Control PT recording features via MIDI from an extenal MIDI device | Montxo | MIDI | 3 | 05-05-2001 08:05 AM |
