Tube or Solid State Poweramp?
Hopefully I haven't missed a post addressing this; however...not being a transistor, tube, amp tech-y - I just love plugging into amps and having great sounds - which type of poweramp makes sense with modelers, tube or solid state?
Maybe I'm not thinking clearly or over-thinking this, but if the modeler models tube tones, wouldn't it make sense to simply amplify (increase the output) the model with as transparent an amp as possible or not? I'm not talking preferentially, I'm talking amplifying sound/output. I also know the cab sim would/should typically be turned off, but maybe not, depending on your preference. Also...I notice in the Avid vid showing the live connectivity options, Sean Halley gestures to the floor when he says it's been plugged into a poweramp, but it's not stated what poweramp. Is that information Avid doesn't want to get involved with or is it available? |
Re: Tube or Solid State Poweramp?
If you're depending upon a tube power amp to add color, then the question becomes "which color"?
So, yes, it makes sense to use transparent amplification. |
Hey Brianiac5150,
There have been a few threads regarding this topic here and over on elevenrackpresets.com and on the gear pages...there are a ton of tube power amps to choose from out there. One really cool looking piece of gear is the tube power amp & a cabinet from 3rd Power Amps...check it out here... http://www.3rdpoweramps.com/product_sv3015.htm Ther's also the stuff from Fractal Audio... http://fractalaudio.com/products-at-reactor.html Some of the more popular solid state choices I've seen mentioned are: Rocktron Velocity 300 A.R.T. SLA-2 Carvin DCM200L Peavey IPR1600 You can also go the powered monitor route...Check this thread out that VSA posted about a couple of monitors that he compared... http://www.elevenrackpresets.com/for...=2746#Post2746 Later Mike .
Lenovo IdeaCentre K430 Windows 7 Pro SP1 64bit PC with 3rd generation 3.4 GB Intel Core i7-3770, 32GB DDR3, 2TB HDD, NVIDIA GeForce GT620 running Pro Tools 11.3.1 and PT 10.3.9 and the ELEVEN RACK! |
Tube vs Solid State | gavriil1 | Tips & Tricks | 3 | 10-22-2013 10:47 AM |
How About Solid State? | Sradio | Storage Subsystems | 43 | 04-04-2013 03:40 PM |
Solid state drives | Calum0405 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-09-2011 07:14 AM |
G5 and Solid State Drives | Dutchmama Studio | Pro Tools TDM Systems (Mac) | 5 | 09-25-2010 01:51 AM |
Has anyone tried the Solid State HDs? | Julia B | Pro Tools M-Powered (Win) | 6 | 04-28-2010 06:28 PM |
