Old 11-12-2010, 05:17 PM
crashhak crashhak is offline
Default cannot remove pop
I was recording guitar track with eleven rack, I did quick punch and put crossfade but I still hear pop. I also used trim tool to connect waveform each other. What am I doing wrong? Any idea?
Eleven Rack
Digi 002 rack
Firmware 1.03
Window vista 32 bit
Old 11-12-2010, 05:31 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: cannot remove pop
if you zoom ALL the way in, can you see the pop? if so, you can use the Pencil tool to redraw the waveform.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 11-13-2010, 10:36 PM
Yes, I see waveform is disconnected each other. It seems solo part is harder
to fix than rhythm part. I will keep playing around with pencil tool until it
fixes. Thanks Benoni.
Does remove PT - remove projects too? Andy Gerome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-29-2008 11:29 AM
Add/ Remove Programs will not Remove Pro Tools powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-07-2005 02:48 PM
I CANT REMOVE PT 6.1.1 SNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-27-2005 11:36 PM
Remove OSX? pag113 Pro Tools TDM Systems (Mac) 3 10-14-2002 05:36 AM
Do I need to remove it. stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-19-2002 11:01 PM
