''not enough RAM''
i just bought the fast track that includes pro tools m powered essential. when i try to install pro tools, it tells me ''Not enough RAM. Pro Tools M-Powered Essential requires a minimum of 1024 megabytes of total system RAM. This machine has only 980744 kb of RAM.'' When i go into the control panel to see, under system, how much RAM my machine has, it tells me 1,00 Gb! so, do i have to delete some stuff to get more RAM ? (which i really don't know how) i really don't know what to do. please, can anyone help me!? SiSoftware Sandra Computer Model : Dell Inc Dimension E521 Workgroup : WORKGROUP Host Name : Diane-PC User : Mathieu Processor Model : AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ Speed : 2GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 2x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size Computer Platform Compliance : AMD LIVE! Mainboard : Dell Inc 0UW457 BIOS : Dell Inc 1.1.4 12/09/2006 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 960MB DIMM DDR2 Chipset Model : AMD Athlon 64 / Opteron HT Hub Front Side Bus Speed : 2x 1GHz (2GHz) Total Memory : 1GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 251MHz (502MHz) Memory Module(s) Memory Module : Micron 8HTF6464AY-53ED7 512MB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Memory Module : Micron 8HTF6464AY-53ED7 512MB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Video System Video Adapter : NVIDIA GeForce 6150 LE (4 PS3.0, 1 VS3.0, 64MB, Integrated Graphics) Graphics Processor Storage Devices WDC WD10EARS-00Y5B1 (1TB, SATA300, 3.5", NCQ) : 932GB (C:) TSSTcorp DVD+/-RW TS-H653A (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 8GB (D:) Logical Storage Devices Hard Disk (C:) : 932GB (NTFS) @ WDC WD10EARS-00Y5B1 (1TB, SATA300, 3.5", NCQ) Pro Tools M-Powe (D:) : 8GB (CDFS) @ TSSTcorp DVD+/-RW TS-H653A (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell MCP51 LPC Bridge LPC Legacy Controller 1 : SMSC SCH5514D-NS Audio Device : Dell MCP51 High Definition Audio Audio Codec : Sigmatel High Definition Audio Codec Disk Controller : Dell MCP51 Serial ATA Controller Disk Controller : Dell MCP51 Serial ATA Controller USB Controller 1 : Dell MCP51 USB Controller USB Controller 2 : Dell MCP51 USB Controller SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1 SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2 Printers and Faxes Printer : Send To Microsoft OneNote Driver (300x300, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP DeskJet 930C/932C/935C (1200x1200, USB, Colour) Network Services Network Adapter : Broadcom 440x 10/100 Integrated Controller (Ethernet, 1Gbps) Network Adapter : Anchorfree HSS Adapter Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Home 6.00.6002 (Service Pack 2) Platform Compliance : x86 Windows Experience Index Current System : 3.0 Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. Last edited by arcticmathieu; 09-23-2010 at 07:22 PM. Reason: details |
Re: ''not enough RAM''
you cant delete stuff to get more ram. You delete stuff to free up space on a hard drive. To get more ram, you buy more ram and install it.
Even though you do have 1GB installed, you have integrated graphics, that is holding 64MB of your ram, so you only have 960MB available for use. Cant you still install even though you get that warning? Some using PT LE said they got that warning, but they could still install and use PT. So if you can still install, try it out.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
