Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 08-07-2010, 04:57 PM
Kafrifelle Kafrifelle is offline
Default ProjectMix I/O Output assign question
I am sure that for many of you this is really a basic question but for me, it has been a nightmare lately ...
I am using SnowLeopard on a MBP
Protools 8 MPowered
ProjectMix I/O as a control surface.
In my FireWire Monitor related to the ProjectMix I/O I see:
output 1/2 out
output 3/4 out
spdif out
in my ProjectMix I/O, I see in the back of the unit output 1 thru 4
At the moment, I am using 1 and 2 as my left and right to listen to my rough mix.
The question:
Is there a way to use the output 3 and 4 and plug that into a separate amp (left and right) for a second stereo mix ? I would like to be able to use this 3 and 4 out for a mix thru another amp and set of studio monitors.
Is it even possible to do ?
Thx for any helpful response.
YP
Old 08-08-2010, 09:30 AM
Default Re: ProjectMix I/O Output assign question
I am guessing, nobody knows ...
Old 08-08-2010, 10:17 AM
kaiserpathos kaiserpathos is offline
I have never tried this with my ProjectMix I/O, but I would think it's possible. I am not in front of my DAW right now, but I remember setting a "Headphone Mix" output on my PMIO -- so that I could move my headphones to the second headphone jack to audition a separate mix (or have a "singing mix" for a vocalist). I'm not sure if my "Headphone Mix" takes up outputs 3 & 4 or not.
Pro Tools has the "Main Out" master fader which defaults to Outputs 1 & 2 on the PMIO, but I can imagine it's totally possible to use 3 & 4 within Pro Tools.
Old 08-09-2010, 09:59 AM
moskasound moskasound is offline
I have yet to try it on my ProjectMix, but sounds like you just create a 2nd Master strereo out and assign to 3&4.
iMac 3.06 Core 2 Duo 27"/4 GB ram
Mac OSX 10.6.4
ProTools, M-Powered 8.0.4
M-Audio ProjectMix
LaCie Quadra Drives
SampleTank
Abelton Live
How do I assign multiple tracks to the same output? MeBangKeys Tips & Tricks 3 04-30-2009 06:05 PM
Sound output assign? manyrains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-19-2009 09:07 AM
Can't assign output, not enough DSP? crizdee Pro Tools TDM Systems (Mac) 2 04-04-2008 12:05 PM
Bug in Sample Output Assign quantise Virtual Instruments 1 03-22-2007 06:51 AM
assign audiosuite preview to output? StainedClass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-12-2003 10:52 PM
