Old 07-01-2006, 01:29 PM
dsmith dsmith is offline
Default PT le 6.7 Midi Problem (cant assign output)
I have the 6.7 le using xp, I'm trying to use pt as a master and have it control a mpc. Its been working for about 6months and all of a sudden it won't let me assign the midi outputs. I even tried creating a new instrument under studio setup, but when I get to the part where it says "input port-output port" it won't let me switch it to anything ( stays on default-none). Please help this is really aggravating.
Old 07-01-2006, 02:41 PM
Default Re: PT le 6.7 Midi Problem (cant assign output)
dsmith
If you go into Control Panel>Sounds and Audio Devices>Audio (Tab)>MIDI Music Playback, can you select a Port from your MIDI Interface?
Are you using Digidesign hardware as your MIDI Interface, if so, what unit?
filosofem
Aaron Mulqueen - 001 HD Native
Old 07-01-2006, 06:57 PM
I'm using the digi 002 rack.
Old 07-01-2006, 07:33 PM
I don't own a 002, so to be fair, I'd be guessing, but have you tried a quick re-install, sometimes for no apparent reason, things get corrupt.
filosofem
Old 07-02-2006, 01:32 AM
Fran d'Valle Fran d'Valle is offline
You must power on the 002 before your computer...
www.digitalsoundstudios.com
Old 07-02-2006, 12:07 PM
I'm going to try that, thanks for the replys.
Old 07-02-2006, 01:26 PM
I tried powering on pt before the computer and still no luck. This sucks. I also checked to see if the pt drivers were running and they looked good .
Old 07-02-2006, 05:10 PM
Bump for hope of figuring this out.
Old 07-03-2006, 07:41 PM
bump, for some help
ProjectMix I/O Output assign question Kafrifelle Pro Tools M-Powered (Mac) 3 08-09-2010 09:59 AM
Sound output assign? manyrains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-19-2009 09:07 AM
Can't assign output, not enough DSP? crizdee Pro Tools TDM Systems (Mac) 2 04-04-2008 12:05 PM
Bug in Sample Output Assign quantise Virtual Instruments 1 03-22-2007 06:51 AM
assign audiosuite preview to output? StainedClass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-12-2003 10:52 PM
