Old 06-10-2005, 07:52 PM
Simpson Simpson is offline
Default Avid editor - needs trim like function
I'm an Avid editor first, pro tools is much newer to me.
In Avid after you cut a clip (of video or audio) you can later extend that clip back out if you cut off too much. Is there a way to do that in pro tools?
Old 06-10-2005, 08:19 PM
Slim Shady Slim Shady is offline
Default Re: Avid editor - needs trim like function
Yes, conveniently enough, the 'trimmer' [F6] tool does this.
In your getting started manual, check out the 'trimming regions' section. If you have the PDF (in Digideign->Documentation) you can search for 'trimmer'
After installing ProTools 11 my Avid IO doesn't function Eric Lambert Pro Tools 11 17 06-22-2013 08:01 PM
Can you trim MIDI regions from inside the MIDI editor window? emspace Pro Tools M-Powered (Mac) 0 07-06-2010 12:13 PM
Score editor not giving Print function. Nathan Rain 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-26-2010 03:13 AM
"Trim" like function needed Simpson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-25-2005 09:27 AM
Edit wheel, the long asked for trim scrub function? Advances? Jules ProControl, Control|24, Command|8 17 02-11-2001 09:32 PM
