Re: windows 7 not
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Re: windows 7 not
It's called "Patches"
Re: windows 7 not
The One-eared Barn Cat OS held some promise, but they couldn't get a mouse to work with it.
Backbeat, it's an easy move from XP to Win7. There's very little you will have to learn. Anyone who is familiar with XP will immediately be at home in Win7. Almost everything will feel familiar, but better. Nearly everything will work faster and more reliably. Just to be safe, install it from scratch on a new drive or freshly formatted partition. That way you can boot to XP when needed. It will let you do that with the upgrade version, which is a bit cheaper. That said, I used PT9 on XP for two weeks for some mixing and editing, and it worked great. I didn't do any tracking with it, so I can't speak to that. But for mixing, one session had 62 tracks and loads of plugs, including a couple of VIs. Never a hitch. My only problem was that the MIDI drivers wouldn't install, so I had no MIDI I/O; but I'm 99% certain that had to do with a problem unique to my system because I had had several other installers fail to work properly over the previous few months. When I upgraded to 7, the same sessions appeared to use a little less CPU than they had in XP, which is consistent with my experience that Win7 is more efficient overall.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Re: windows 7 not
Thanks again guy's I'll stay with windows see ya at the grammies
Re: windows 7 not
I've run PT9 on identical hardware mac/win7-64... PT9 is 1000% more stable on the mac. And on the rare times it does crash - no system reboot needed. On the Win7 x64 side - random crashes - odd problems with RTAS processing - and the annoying "cannot save" bug - and then you have to reboot. You can get it to work on Win7 - but its just not as smooth running as on OSX.
If I were building/buying a new machine for PT9 - I'd definitely get a Mac. -Dan |
Re: windows 7 not
That's true at the moment. But they'll sort it out in the next cs or two, if they wanna live.
Re: windows 7 not
So if you can run PT9 on XP, has anyone been able to use an 001 with it? I have an 001 rig that would be cool if I could use PT9 with
Re: windows 7 not
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Re: windows 7 not
Yes- I would say that "runs 1000% better on a Mac" is a wee bit of an exaggeration.
Re: windows 7 not
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' NO, SHE'S WITH HOBO KEY '' (that dopey green thing) ('we' must start using pronouns) |
Updating Pro Tools and Mbox from Windows XP to Windows 7 | ryanjantz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-29-2011 04:22 PM |
Windows Guide - Windows 7 Optimizations and Troubleshooting.[349411] | cwsand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-12-2010 01:46 PM |
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? | VonHelvete | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-28-2010 10:01 AM |
running PT 8.0 in windows XP virtual machine on windows 7 | Jenk2k | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 03-17-2010 08:45 PM |
Windows server 2003+windows resource manager. | odysseys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-20-2003 10:02 AM |
