Old 12-13-2010, 04:55 AM
ejwells's Avatar
ejwells ejwells is offline
Default Re: windows 7 not
Originally Posted by guitardom View Post
not sure how up you are on it, but mac has TONS more os upgrades/updates than windows EVER has. xp was the main os for how many years???? 8??? now research how many different os's mac has had in that same 8 year period or so. i cant even start to come up with all the versions with cat names......
In honor of Happyland, I think Mac should announce a "one eared barn cat" OS.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 12-13-2010, 05:36 AM
They have.
It's called "Patches"
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
Old 12-13-2010, 07:04 AM
daeron80 daeron80 is offline
The One-eared Barn Cat OS held some promise, but they couldn't get a mouse to work with it.
Backbeat, it's an easy move from XP to Win7. There's very little you will have to learn. Anyone who is familiar with XP will immediately be at home in Win7. Almost everything will feel familiar, but better. Nearly everything will work faster and more reliably. Just to be safe, install it from scratch on a new drive or freshly formatted partition. That way you can boot to XP when needed. It will let you do that with the upgrade version, which is a bit cheaper.
That said, I used PT9 on XP for two weeks for some mixing and editing, and it worked great. I didn't do any tracking with it, so I can't speak to that. But for mixing, one session had 62 tracks and loads of plugs, including a couple of VIs. Never a hitch. My only problem was that the MIDI drivers wouldn't install, so I had no MIDI I/O; but I'm 99% certain that had to do with a problem unique to my system because I had had several other installers fail to work properly over the previous few months. When I upgraded to 7, the same sessions appeared to use a little less CPU than they had in XP, which is consistent with my experience that Win7 is more efficient overall.
David J. Finnamore
Old 12-13-2010, 10:10 AM
backbeat backbeat is offline
Thanks again guy's I'll stay with windows see ya at the grammies
Old 12-14-2010, 05:54 AM
WinTaper WinTaper is offline
I've run PT9 on identical hardware mac/win7-64... PT9 is 1000% more stable on the mac. And on the rare times it does crash - no system reboot needed. On the Win7 x64 side - random crashes - odd problems with RTAS processing - and the annoying "cannot save" bug - and then you have to reboot. You can get it to work on Win7 - but its just not as smooth running as on OSX.
If I were building/buying a new machine for PT9 - I'd definitely get a Mac.
-Dan
Old 12-14-2010, 06:52 AM
That's true at the moment. But they'll sort it out in the next cs or two, if they wanna live.
David J. Finnamore
Old 12-14-2010, 02:19 PM
a100man a100man is offline
So if you can run PT9 on XP, has anyone been able to use an 001 with it? I have an 001 rig that would be cool if I could use PT9 with
Old 12-14-2010, 04:03 PM
-Dan
This is not a "w7" issue, this is "your computer" issue. I have none of the problems you speak of and I run very large sessions and is running great.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 12-14-2010, 04:13 PM
ejwells's Avatar
Yes- I would say that "runs 1000% better on a Mac" is a wee bit of an exaggeration.
Old 12-14-2010, 04:38 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Updating Pro Tools and Mbox from Windows XP to Windows 7 ryanjantz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2011 04:22 PM
Windows Guide - Windows 7 Optimizations and Troubleshooting.[349411] cwsand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-12-2010 01:46 PM
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 10:01 AM
running PT 8.0 in windows XP virtual machine on windows 7 Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 03-17-2010 08:45 PM
Windows server 2003+windows resource manager. odysseys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-20-2003 10:02 AM
