midi drum tracks in pt8
so, up until now I have been using a seperate instrument track for each drum sound, kick, snare, hi-hat etc, and insert my instrument on each of the tracks, im using komplete7, so its pretty taxing on the cpu... my question is, because im usually using the same kit, can i record everything on the same track and then jus aux out each drum sound to another track without having to insert the instrument onto each subsequent track? i just want to find ways to conserve cpu power, i can continue doing it the way im doing, just wondering what is best for midi drums...yes, im a novice producer, but not a novice songwriter/performer,lol...i can get my songs out pretty well, but they just seem to take ages...i need to find ways to speed everything up... thanks in advance to all who respond |
Re: midi drum tracks in pt8
Can't you just instantiate the VI on one stereo track and turn down the volume. Then set up as many aux tracks as you need and set the input to each track from the different output channels of the VI? I am not familiar with Komplete 7 but I know with strike you can do it.
You would set the kick to output 1 and make that the input on the 1st aux track. The snare to out 2 and use that as the input to aux 2 etc. |
I have a question along the same vain - new to Pro Tools (have Le 8) and will be getting a drum controller soon. I have a lot of experience with drum producing in other software and generally like to run different 3rd party FX on each drum hit (but with a consistent reverb track to bring it all together).
What is the best software for MIDI drum mapping in Pro Tools to achieve this effect? I'm not looking for software that provides samples as i have all that - just something to go hand in hand with an MPD or PadKontrol that achieves the above... All help appreciated |
For starters, ezdrummer and SD2 both allow a single Instrument track to be split out to mutli-track(either AUX or AUDIO) so you can mix and treat the entire kit just as you would for a multi-tracked acoustic kit(can't speak for other drum programs but I imagine most can do this). SD2 and EZ also have a built-in mixer page and you may find that adequate for your needs. sproyd should start a new thread as that question is really a separate issue. BTW, I trigger my drum VI's with both a Roland TD-10 kit and an M-Audio Trigger Finger, with excellent results. The ultimate for me is the Roland kit with real cymbals and hat, with 3-4 mics.
drum/midi tracks? | Intelli-Shred | The Drum Room | 4 | 02-27-2012 11:21 AM |
midi recording drum tracks | elv1s1sal1ve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-30-2005 08:34 PM |
MIDI Tracks to Drum Machine | M Offutt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-05-2005 04:34 PM |
sync midi drum tracks to wav tracks | Adrian D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-14-2003 12:24 AM |
MIDI Drum Tracks in PT | NormCouturier | General Discussion | 1 | 11-15-2000 09:30 AM |
