Repairing Disk Permissions
I need to designate a couple of drives as AUDIO VOLUMES and simply trashing the Digidesign Databases and restarting isn't doing the trick. Question is, can you run Disk Utility on these external drives without having to startup with a seperate OSX System Startup Disk? I don't even "have" a seperate startup disk anyway as my system was bought from an individual and it wasn't included. Or, is there a way to "create" a clean OSX Startup Disk? Anyway, however it gets done, I need to get these drives where they are not simply Playback or Transfer only.Or, do I have to reformat these drives again? Thanx...Ron Fairchild PT HD3 7.2 on OSX MAC G4 with not as much RAM as I would like!
Re: Repairing Disk Permissions
Assuming they are not your startup drives, you can run DiskUtility on them and reformat them or repair them.
If there is nothing on them then reformatting is the best option (Mac HFS+ journalled). You set them to RECORD, PLAYBACK or TRANSFER in the workspace browser. |
In workspace is it not possible to change these to "R" in the columns for audio and video? If not then you'll need to right click on the drives and go to get info and the look at details/ ownership & permission and set owner to read and write!! then you'll have to log out and then back in again and that should reset them for read and write operations. Chris
Thanx to you both. I will try this tomorrow morning when I get back. I am sort of "new" to MAC OSX, coming from a PC world when I was LE. Logging in and out is a different animal here from the other world. But I knew that when I could not designate "R" from WORKSPACE that I was looking at a PERMISSIONS issue. I can reformat if needed since there is not much on either drive to remove. They are just "parking" some large sessions that need to be archived anyway.----Ron Fairchild
It's a done deal. Thanx. Things work a bit different in OSX as opposed to a PC!!! Once you do anything once it becomes a simple thing from there on... The Journey Continues......
Ron,
I can't stress this enough: RUN, don't walk, and get an OSX startup disc. In a perfect world, it will have the version of OSX that you are using. In case of disc problems, ONLy the apple startup disc will save you. Some of these are DVDs and also include Apple Hardware Test on it. You ahve no way to re-install your OS if something should happen... "archive and install" is a common solution to correct OS issues... you are out of luck if you need to do this... If you can find the "restore" disc(s) for your hardware that would be ideal. You may find what you need on ebay? Hope this helps.
--Jeremy |
Apple disk utility repair disk permissions | vga | Pro Tools TDM Systems (Mac) | 8 | 05-11-2010 11:10 AM |
Repairing Permissions Daily / PT8HD | Logichead | Pro Tools TDM Systems (Mac) | 0 | 02-17-2010 07:22 PM |
Repairing permissions takes 8 hours??? | IO Composer | Pro Tools TDM Systems (Mac) | 5 | 04-18-2009 04:04 PM |
Repair Permissions: Disk or DVD? | dubaifox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-21-2005 07:58 PM |
DAE Error -1 after repairing permissions | Lee Blaske | Pro Tools TDM Systems (Mac) | 6 | 03-06-2004 07:57 PM |
