Old 03-29-2021, 10:15 PM
larsongs larsongs is offline
Default Re: Buffers Size, Sample Rate & Sample Latency??
Originally Posted by Top Jimmy View Post
I haven't seen it mentioned in the thread yet, but how are you assuring all the tracks stay together in time? I would expect that as everyone contributes in this workflow, they all need provide audio files that start at time 0, or bar 1 beat 1. If everyone provides files that start at the same place, then everyone else can spot those files to the same starting point in their session and all will be good. In Pro Tools, there is the consolidation command that will let you consolidate everything on a track from your starting point to the end in one file.
As I previously mentioned.. We are all doing a 4 Count from beginning or (0)..
I’m not explaining myself very well... All of us are at same BPM, same Buffer, same 4 Count from beginning of the song. The Drummers Click Track doesn’t sync with mine. Frustrated the Drummer proceeds to Chart the song & records a perfect Drum Track to his Click.. Then he loads it to the Folder.. When I upload it to my Project it isn’t in sync with my Click. There is latency between my Tracks & his Tracks. Because for some reason, even though all of our Settings are equal, our Clicks aren’t in perfect sync..
My previous Post posed a possible Work Around.. Does anyone have any thoughts on that?
Thanks
Old 03-29-2021, 11:21 PM
Top Jimmy's Avatar
Default Buffers Size, Sample Rate & Sample Latency??
Thanks
Here's what I haven't understood this whole thread. If the drummer's tracks aren't faster or slower, why don't you just slide them into place? What's with all this getting distracted with stuff that won't have an effect on the end result? If you're not good at sliding it into place have the drummer provide a bit of his click so you can slide all the drums into place against your click.
And yes, starting everyone from the same click printed as an audio file should do the trick. No one would need to fiddle with that stuff in their own DAW. Just play to the click track.
James Cadwallader
Old 03-29-2021, 11:35 PM
Sardi Sardi is offline
Why does your drummer continue to use his own click if you’ve provided him with a printed click? The latter is what he should be using.
Is he the only one experiencing the issue and is he the only one insisting on using his own click? If so, you’ve found your problem.
If you’re all using the same click track printed as an audio file that is the length of the session (no copy and paste or looping) then there is zero reason for everyone to not be in sync... sloppy timing aside.
Either your drummer’s name is Lars or you possibly (as mentioned above) have a sample rate mismatch.
Old 03-30-2021, 06:59 AM
Sliding his Click doesn’t work.. It starts out the same but by 1:30 or so it seems to go off & from that point on our 2 Clicks are out of sync..
I’m going to suggest we all use the Audio Click Track the initiator of the first Tracks provides. Not their own... That seems like the simplest work around.
Thanks all...
Old 03-30-2021, 07:00 AM
JFreak's Avatar
JFreak JFreak is online now
That is samole rate mismatch then. Check there are no pull-up or pull-down anywhere
Janne
  #16
Old 03-30-2021, 08:50 AM
I’ll try to read up on that..
What is a sample rate mismatch? How do you check there are no pull-up or pull-down anywhere?
Thanks
  #17
Old 03-30-2021, 09:31 AM
JFreak's Avatar
Have you ever checked your session setup?
Janne
  #18
Old 03-30-2021, 02:43 PM
In what respect?
Keep in mind we’re 5 Guys all using different Gear.....
  #19
Old 03-30-2021, 02:44 PM
JFreak's Avatar
Pull-up or Pull-down, if not plain and simple sample rate mismatch
Janne
  #20
Old 03-30-2021, 04:35 PM
With the additional info mentioned, I don’t think it’s a sample rate mismatch. If it was, it would be going out of sync straight away, not after a minute and a half.
I wonder if different DAWs calculate their BPM in different ways? Loaded question, but I’m kind of curious now.
Either way, tell Lars to stop using his own click. Makes zero sense for him to do that if you have a printed click audio track. I honestly don’t know what he was thinking doing that.
Hopefully an easy one for you guys: Opening 8 KHz sample rate / 16 bit sample size sample Pro Tools 11 2 02-24-2016 01:04 PM
What sample rate is everyone using? innermusic Pro Tools 10 36 02-26-2012 05:29 PM
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up finalcut Windows 12 02-20-2012 04:00 AM
MBox Micro Sample Max Sample Rate Only 48 kHz? Joe Sciacca 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-07-2008 12:52 PM
Bit Rate/Sample Rate problem? The chipmunks? bspro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2008 05:40 PM
