Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 06-28-2018, 01:43 PM
DAPG DAPG is offline
Default Cedar DNS fader mapping
I am new to the S6. When mapping my Cedar DNS to a fader expander, is there a way to map the "learn" button to a switch or fader? It was super easy on the Icon; can't figure out if it's possible on the S6.
Roy Machado
Dallas Audio Post
Old 06-29-2018, 07:12 AM
creativecontrol's Avatar
Default Re: Cedar DNS fader mapping
Greetings,
I suggested pagetable layout changes for CEDAR DNS One which included the Learn function on switched controls of the 8th fader while the plug-in is expanded. I'm not sure if they ever implemented my changes as I don't have a license to check it. Please let me know what you find and we can feed it back.
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 06-29-2018, 08:25 AM
The learn button does not show up at all on the S6. Any help from you to get it implemented would be fantastic.
Thanks!
Roy Machado
Dallas Audio Post
Old 07-02-2018, 07:36 AM
Looking at the factory (ProControl) mapping it looks like in Channel view (not expand) you should be able to press the IN button for the encoder corresponding to Level. Can you check this out please? I don't have a current license for this plug-in so I can't test it myself. Thanks.
Jeff
Jeff Komar
Old 07-02-2018, 07:59 AM
No, in channel view, the IN button for the "Level" encoder does not engage the "learn' function.
I emailed Cedar support regarding this issue and have not heard back from them yet.
Thanks!
Jeff
Roy Machado
Dallas Audio Post
Old 07-02-2018, 08:10 AM
Thanks for the verification. I will also engage the developers to revisit these optimizations.
Best,
Jeff
Jeff Komar
Old 07-06-2018, 07:49 AM
So on further inspection (and thanks to the nice chaps at CEDAR for a demo license), I discovered that the pagetable looks just fine, however there is an Avid issue with how switched functions are currently behaving in Expand mode. If you test out the DNSone in channel view (vertical) you should find that that Sel switch associated with the Range encoder correctly triggers the learn function. For Expand, this is mapped the same way on the 8th encoder where the Range parameter lives as you can see in the map below. This Channelstrip thread posted recently appears to be the same issue which we are currently investigating:
http://duc.avid.com/showthread.php?t=400084
I will feedback once we know more. Thanks for finding this!
Jeff
Jeff Komar
Old 07-06-2018, 08:33 AM
Thank you for following up! I really appreciate all of your work to figure this out.
Roy Machado
Dallas Audio Post
Old 12-20-2018, 08:48 AM
PT 2018.12 has fixed this issue! Thank you Avid! and Thank You Jeff!!!
Roy Machado
Dallas Audio Post
Old 12-20-2018, 08:56 AM
Good to hear. Yes, engineering found the issue affecting plug-Ins: Insert parameters in expand view with regard to switched functions. Thanks for the confirmation.
best,
Jeff
Jeff Komar
Cedar DNS vs TC vs RX3 jkess Post - Surround - Video 11 02-23-2015 02:38 PM
Cedar DNS One MIKEROPHONICS AAX Plug-ins 0 11-21-2013 06:26 AM
WNS plugin fader mapping Tim R. System 5 5 06-19-2013 08:46 PM
Mapping Mapping Mapping! Please Digi, Hear Us... relaxo MIDI 0 11-03-2005 09:44 AM
mapping controller to audio fader Charles Schaefer MIDI 2 01-15-2004 02:46 PM
