Reset Paths-I/O setup.
I have found that when I work with some sessions that come from a client with diffrent I/O setups then myself and I wish to reset I/O paths it does not work.
Example: I have a session that was saved with only 8 I/O paths. I open that session on a 4 interface system and wish to reset the path settings by hitting "Default" In I/O setups page. And nothing happens. Per the manual 5.1 (page 65) "The default button in the I/O Setups dialogue provides two primarry functions: Creates New, Default paths up to the capacity of your systems available audio interfaces and resources, - Resets selected path names to matching or corresponding paths in the current I/o Setup configuration. I do not find this to be working on sessions whos i/o setups were created on a 1 888 machine then opened on a 4 888 machine. In those cases hitting "Default" does not return the i/o setups to factory settings. I.E assigning a Input and output for each and every available I/o! Please help, has anyone else experienced this problem? |
Cannot create multichannel paths under Setup I/O | MGalway | Pro Tools 9 | 3 | 06-02-2011 10:19 PM |
Question about Sub Paths and Main paths. | oulablank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-15-2009 12:15 PM |
reset the channel strip setup | pmueller | VENUE Live Sound Systems | 7 | 07-07-2009 06:10 AM |
I/O Setup, Bus paths ect. | bradwarren | Pro Tools M-Powered (Mac) | 2 | 05-13-2008 03:07 AM |
PFL/AFL paths | Robin Reumers | Pro Tools TDM Systems (Mac) | 1 | 09-04-2006 11:39 AM |
