Application Switch - Mixer View BUG
EuCon 3.5, PTHD 12.7.1, macOS Sierra 10.12.3:
When I command-tab to another application (SoundMiner, RX, etc.) while PT|Control is in Mixer view, when I go back to PT, the view snaps back to the first 8 tracks. This feels like a bug, because you don't see that behavior in Tracks, Channel or Soft Keys view. Thanks for reading Eddie! This is probably on Ideascale, but if not, I can add it.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
Re: Application Switch - Mixer View BUG
I'm not seeing this here, can you make sure you have PT locked to the surface too and see if that makes a difference ?
PT is locked. I run into this now 40% of the time. What happens is this behavior sticks for a while (10 or so application switches) and then goes back to normal. I'll look more closely to get you the exact steps to recreate. Thanks Eddie.
I am seeing this too.
Richard Spooner Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM. www.spoonsound.com |
Can you guys make sure you do this if on a Mac Clean Eucon Script
Or Uninstall and Reinstall if on Windows. |
Same here. Followed Eddie's instructions and put EuCon 3.6 in, Mixer view still jumps when switching applications. And I'm locked to PT. Weird.
Fixed in Eucon 3.6.1! Thanks Eddie. It's the little things that count...
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn Last edited by reichman; 07-10-2017 at 04:12 PM. Reason: spelling |
Pro Tools hangs after every application switch | legasafe | Post - Surround - Video | 16 | 08-20-2015 02:26 AM |
Application Manager Bait and Switch | Sonny Keyes | Pro Tools 11 | 3 | 06-15-2015 11:34 AM |
How can I keep my mixer view in view? | Sam C | macOS | 14 | 05-16-2013 02:16 PM |
Application switch key and shift layer | aptmusic9 | Artist Series | 0 | 05-04-2012 04:10 PM |
Switch a track to playlist view from D-Command | bvirkler | ICON & C|24 | 6 | 01-12-2011 08:06 AM |
