#21
Re: Cloud Collaboration cost
500MB is not enough for one project, let alone 3. Looks like a really obvious way to make you get an extra plan or not use this at all. Should at least be 1 GB for already paying subscribers.
#22
Re: Pro Tools 12.5 preview
Curious, re: Dropbox, do you work on sessions where the whole session folder itself lives in a local, Dropbox-synchronized folder, and updates/synchronizes with Dropbox cloud as you (and others) work... will Pro Tools run in that scenario?
#23
I thought that the free pack gets you two collaborators, while the premium pack gets you two ADDITIONAL collaborators ..... i.e. 4 collaborators in total. But going back and re-reading it, I see even the free pack uses the word 'additional', so it seems the premium packs don't get you any extra collaborators. It also says 'per project', so each project can have two completely different collaborators. When comparing it to Steinberg's version of cloud collaboration, this is obviously Avid's way of limiting data transfer, whereas Steinbrg doesn't limit the number of collaborators, but charges for data transfer once you've used your free allocation. Personally, I prefer the flexibility of Steinberg's offering, but, in reality, I don't see myself using either company's facility all that much. In fact, though, it is more likely I'll use Avid's, as the one scenario I can see is allowing my assistant to get started with initial editing work while I'm still tracking. In that case, data transfer throughput could be much higher, which new takes passing back and forth, and the main issue will be to comp and render edits efficiently to keep within data storage limits.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
#24
No, how I work in Dropbox is in two scenario's. One I'm the mixing engineer, and the client records in a different DAW; so they upload truncated tracks into the Dropbox and then I load them into ProTools to mix. In this scenario, Collab is with PT is not relevant. The second is I'm the recording engineer and someone else is mixing it. In the past, if they ran pro tools and had the same plugins, I would load the session with the files up. Generally, that's not the case, so as I complete tracking, I upload truncated tracks to the Dropbox for the mix engineer to load in their DAW of choice. For those of you wondering, what's truncated?, it means all tracks start at the same Bar. That way whoever gets it can just load it in and have it line up. You have no idea how often I get tracks that are not like this. It may not be as fast, but it's faster than the additional cost of going from 500mb free to 20g/month. Sometimes sessions take over a year! That's a huge expense, that I'm not carrying, that's billable. Clients won't like that! :P
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
#25
Very cool, thanks, was wondering about that!
#26
Hi Guys,
Info posted here on the plans and pricing and how the lossless compression can make the 500MB free plan work as a starting point. http://www.avidblogs.com/get-started...for-pro-tools/ We are working hard to make sure that everyone's experience with collab and the servers is a great one, so for now the limit of 2 collaborators and this set of offerings is where we feel we can ensure the best overall experience. You can also see the videos that were part of the recent webinar. Thanks much, Tom
Tom Graham Avid Audio Marketing Pro Audio and Mixing [email protected] Check out our Pro Mixing Webinars : http://www.avid.com/US/resources/pro-mixing-webinars Avid Pro Mixing Blog: http://www.avidblogs.com/promixing/ |
#27
Well Tom, credit where credit's due .... The cloud collab functionality as shown in the blog videos is very impressive.
While I don't think I'll be a big user of it, I can certainly see that Avid has put a lot of thought into how to make this a genuinely viable workflow for people that need it. I can see one element of my workflow where this could be very useful, i.e. to allow an assistant to work on edits and comping while I continue tracking. My main concern is what the effect of this major new feature set might be on the general stability of PT, especially as many of us continue to encounter a less than robust product as it is. And, of course, what impact correcting any issues with this new flagship functionality might have on the timsescales for fixing outstanding issues with the current (pre collab) feature set. Nevertheless though, well done so far for coming up with a collab feature set that actually seems well thought out. One question that does come to mind, given that we are limited to two additional collaborators .... Will it be possible, once a collaborator has competed his/her work, to 'delist' that collaborator, thereby opening up a slot for another collaborator to be added?
#28
Some might not know, but a trick to keep another version of Pro Tools side by side on Mac is to change the name of the app to say 'Pro Tools 12.4' and then 12.5 will install in addition to the old version. That way if you are concerned about stability - you can easily run either one without rebooting. So yes - you can 'delist' a current collaborator and then invite a new one. And or - a person can leave as a collaborator on their own.
#29
PS - no ones made any jokes about my song yet…
#30
That would be mean wouldn't it? Honestly I haven't seen it, but I am in the camp with Sir Nigel....glad you got it to work and wish you well but I am not planning on using the features I have a setup in the country, and bank on people coming to me... :) BTW - When are you gonna sell me your used D-Command ? Cheers
Avid Everywhere / PT Cloud Collaboration | peter5992 | General Discussion | 1 | 03-16-2016 08:26 AM |
Cloud Collaboration | hacha | Foro en Español | 9 | 07-07-2015 08:53 AM |
Yes to cloud collaboration! | reichman | Avid Cloud Collaboration | 91 | 06-17-2015 09:07 AM |
Cloud collaboration vs real collaboration | midnightrambler | Pro Tools 12 | 13 | 06-11-2015 01:48 PM |
Cloud Collaboration Cost? | SearingSounds | Pro Tools 12 | 3 | 01-28-2015 08:38 PM |
