Old 04-17-2009, 08:12 AM
alesssss alesssss is offline
Default How can I install the loops?
I upgradated PT7.4 to 8.
I Downloaded from the digidesig site PT8, some pdf and seven loops zipped (i.e. jazz_55868.zip; hip_hop_56860.zip etc...)
how can I install that loops?
Thank You
ales.
Old 04-17-2009, 09:31 AM
ankely ankely is offline
Cool Re: How can I install the loops?
Just put the loops on a drive, external firewire, and drag and drop them into your projects.
Hope this helps.
Pro Tools 10.3.9, MBP 2.4GHz Intel Core 2 Duo OS 10.6.8 4GB/Ram, 7200RPM 750GB Internal HD, Focusrite Saffire Pro 40, Digidesign Mbox 2.
It is what it is...
ScrewMakerMusic
Old 04-17-2009, 09:48 AM
spkguitar's Avatar
Default Re: How can I install the loops?
The loops are just audio files. There are many, many ways that you can use them in a session.
First, you need to unzip them to your hard drive somewhere.
Then, and probably the easiest way to use them, pick the one you want to use and drag it into your session. Simple, right? It's actually a little bit more complicated because you have to sync tempos and Time Compress or expand some of them to get them to work properly.
All of them have demos session included, though, so you might want to open the demo sessions to have a look at how they are using them there. (In your own sessions, I would try to steer away from the digital overs that are in the demo sessions, though)
You could also load them into your favorite sampler (like Structure free?), but that would be a little more on the technical/advanced side of things.
Old 04-17-2009, 09:50 AM
audiogeekzine audiogeekzine is offline
Just don't keep them on your system drive.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 04-17-2009, 03:46 PM
fridrikur fridrikur is offline
Protools 8 setup doesn't install those files in any folder and the install program doesn't look for them either, so it is safe to just threat them like any loops from a dvd or cd any copy them as suggested by the other members here. Just like you I was also confused about where to put the files, but I came to that conclusion. I was just curious to learn if those who bought pt8 on dvd had any automatic installment of those loops from the pt8 installer. It doesn't really matter I am just an perfectionist and like to have my files in the right folders :)
Intel(R) Core(TM)2 CPU 6400 @
2.13GHz
Intel Corporation DQ965GF
Memory: 2GB
ST3250310SV 250GB (SATA300, 3.:233GB (H:)
ST3320620AS 320GB (SATA150, 3.:298GB (C:)
External Harddisk: Lacie D2 Quadra 1 TB firewire 400 (Oxford 11 chipset - using a different firewire card than fw410)
Windows System: Microsoft Windows 7 64 bit ultimate
M-audio Firewire 410 (ADS PYRO PCI 64 bit firewire card with Texas instrument chipset)
(6.0.1_5.10.0.5058)
Pro Tools M-powered 8.03
Old 05-12-2009, 10:08 PM
Coligreens Coligreens is offline
Maybee you can help. i interupted my downloads of these loops - the hip hop and the R&B funk Soul and i cant find where i download them from. it was right after i upbraded to ptle8
Old 05-13-2009, 12:59 AM
Avid's Avatar
Avid Avid is offline
Administrator
If you received Pro Tools 8 as a download, the loops would be in your My Digi account:
www.digidesign.com/mydigi
Registered Downloads -> View All -> Pro Tools M-Powered 8.0 Upgrade
Administrator
Old 05-14-2009, 03:33 PM
I will gladly help and I agree with alesss. You can log on to your digidesign account and there you can find the download files, including the big fish loops which they are called. I can understand if you think it is confusing. I tought so too, untill I realized that they were 'just' loops so in fact could reside anywhere, and thus could be installed where ever I wanted them to be.
2.13GHz
Memory: 2GB
(6.0.1_5.10.0.5058)
Old 04-19-2012, 06:39 PM
Amodeo Amodeo is offline
If you click and drag into your session, why does it matter where you keep them?
Old 09-30-2013, 11:34 AM
exact1 exact1 is offline
Default Big Fish Loops
Hi everyone,
I have pro tools 10 and it came with some Big Fish Loop downloads. I've been looking for one-shots such as long-kicks and short kicks.
Does anyone know where I can find these?
Workspace loops Elastic analysis.. doubles loops Rectifried Pro Tools 11 1 04-03-2016 08:43 AM
How do I install loops and demos on seperate drive? falcon4 Pro Tools SE and Essential (Win) 2 02-18-2011 01:36 PM
PT 9 Install on FF800 -> Loops skippy Pro Tools 9 5 01-12-2011 05:24 AM
PT9 Audio Loops Disk- How do I install/access them? nikdanger Pro Tools 9 5 01-02-2011 04:22 PM
Best place to install loops and samples? Sounds like...! 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-11-2010 04:36 PM
