Old 04-28-2007, 10:17 PM
Default No go zone
Is it me ...or is Strike and Structure a no go zone?
Without fail, instantiate Structure and down she comes ...a slight exaggeration, however, not far from the truth. I mean, Strike isn't the most stable even on it's best days, let alone introducing Structure to the party, conversly, before digging myself a deeper hole, I know Structure is only in it's primarily beta stage, but expectations of air tight A.I.R. group VIs would be upmost paramount, no?
Faithfully.
filosofem
Aaron Mulqueen - 001 HD Native
Old 05-05-2007, 10:44 AM
webby webby is offline
Default Re: No go zone
How much RAM do you have in your system?
I know Strike can require lots of RAM as it loads drums/samples into RAM. You know you can set a maximum about of RAM to use in the Strike settings right?
I'm running Structure and Strike here no problem. Infact I also have Vevlet and Xpand in session too.
Old 05-05-2007, 02:06 PM
Hi webby
Yeah mate, currently I have 4 gigs of RAM and the Strike Content Size Configuration is set at 'Unlimited' and apart from a 'Reduce Content Size' message I receive whilst opening Strike, XXL settings load no problem. In fact I also run Velvet at XXL too no problem, but as soon as I open Structure, load a Patch or two, or drag & drop, down she comes. Structure is the only AIR group VI that isn't stable, all the others Xpand!, Hybrid, Velvet and Strike have just been plug and play.
What platform are you running, my DAW is an ASUS K8N-DL 265 AMD Quad, XP Pro, LE 7.3.1 cs2?
I have to admit, I do envy you, Structure is a great VI and there have been so many times I've just wanted to drag it out, but way to scared too, as I said, no issue with the other AIR group VIs, it just make me conclude that Structure in it's Beta stage is at fault.
filosofem
Old 05-19-2007, 05:46 PM
Wow! Since the revision, what less than three days ago? Structure has been working flawlessly, all AIR group VIs in the same session have been running basically none stop without a single crash. I don't know what's changed, but Structure 1.0.4851 is rock solid!
filosofem
Help... trying to add filters to a zone and it doesn't work uno1234 Virtual Instruments 0 11-15-2007 02:58 PM
twilight zone Steve MacMillan Pro Tools TDM Systems (Mac) 3 01-16-2004 03:25 PM
The DIGIlight Zone BesnikB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-17-2003 02:38 PM
PC crashed on me.... help!... I'm in the 'Zone' right now.... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 38 03-13-2003 10:02 PM
RED ZONE stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-02-2001 08:02 AM
