Re: Hard Drive advice
My 2 ¢ worth...I prefer outboard drives for everything that's not on the start-up disk. ClubMac makes some stackable firewire drives and CDR's that have been working out well for my multi-computer config...and since Roxio Toast will allow multiple simultaneous CD burning on a single computer...life is good!
I'm not sure what you'd use the 80GB system drive for, but I suppose you could always use it for a quick backup of sessions created on the other drive. Then you could burn them to CDR at your leisure.
I'd partition the 80GB audio drive into something reasonable like 12-15GB partitions. You'll get slightly better performance out of it. It'll also be a little easier to manage: name one "current projects"; one "demo software"; one "Sammy's stuff" (assuming you work with "Sammy" [img]images/icons/smile.gif[/img]), etc. I use a single 17" CRT myself, but one-for-one, people who have used dual-monitors rave about them and never want to go back to a single monitor. Personally, I think a 15" is a bit small (my 17" is really a bit small). Dual 19" LCDs would be the ticket. However, a 15" + a 17" might be OK. Others will probably chime in...
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Hard Drive advice
I am going to order a new G4 to use with Digi 001. My plan (since I need lots of disk space) is to oder a 733 mHz G4 tower with the two 80 gb Ultra ATA drives. Is this reasonable, or should I consider another drive configuration?
Also, I plan on getting a 17" LCD display. Will I have enough room on that to keep the transport, mixer and tracks all in view and usable at the same time? Or would it be more reasonable to go with a 15" LCD display and a second video card, so I can keep the tracks on the lcd and put the mixer and transport on an old 15" crt I have laying around? |
Considering OWC external hard drive - advice?! | young.don | Storage Subsystems | 7 | 06-23-2011 09:33 AM |
hard drive advice for new mac pro | therecordinghouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-01-2008 09:16 AM |
EXTERNAL HARD DRIVE ADVICE | jessmeaniesaid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-15-2006 02:41 PM |
External Hard Drive Advice | benrice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-12-2006 08:30 AM |
Need some hard drive advice | yin7yang64 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-06-2001 09:52 AM |
