Virtual soundcheck
I am getting ready to do a live xmas production show and would love to use virtual soundcheck as well as deliver master audio tracks to the client. We have owned our Venue D-Show for a while now but I have not interfaced a Pro Tools rig in to it yet. I do have the HD card installed and will be recording 48 tracks at 48/24. I am looking for some advice on the best type of hard drives to use, internal or external, eSATA, firewire 400 or 800, partitioning, sample and bit rate, etc. The show is about 2 hours long and there are five shows over the course of four days. We have a local guy that will be bringing his Pro Tools Mac rig. While I am a D-Show guy, I'm just not a Pro Tools guy and need some advice. Thanks.
Tom |
Re: Virtual soundcheck
I would definitely recommend either the Lacie FW drive 800 bus or the internal SATA drives. Make sure that for stability in Protools while recording to divide your tracks among multiple HD's. Digi recommends 24 tracks per HD. I made a mistake in the beggining recording 48(-+) tracks to one HD and started getting a lot of errors, then I divided them into mutliple HD's and everything is fine! Now I'm recording 70-80 ch's no problems. Hope that helps!
Does the guy thats bringing his PT rig have storage? Typically for a track count like that you should be able to allocate between a couple of FW400 or 800 drives. Do not use the system drive for any storage. As far as from your console you will just be assigning direct outs which is easy to do from the patch bay.
T |
Tom |
and assign 24 trks to 1st partition and 24 trks to 2nd partition even through technically it's the same hard drive physically? Or is it better to go ahead and use different drives physically? thanks, getting ready to get the profile w/ virtual sound check option so I will need to know how many drives to buy for at least 48 trks maybe 64trks recording. Rob Warren |
Music business is serious business. |
Hi Rob,
Sheldon |
I'm currently experiencing pops and clicks in my audio. Is this stemming from my current drive not keeping up? It seems my audio usually doesn't have artifacts until close to the end but occasionally it's started right after the beginning. I'll give dividing the tracks a try but would love to have more insight into the problem.
crt |
Pops and clicks usually indicate a digital clock issue. Please tell us more about the setup - how are the tracks being monitored? Through the console or through another Pro Tools peripheral? If it's the latter then the peripheral needs to be word clock connected to the console in order to establish a common clock. Sheldon |
Can an SC48 do Virtual Soundcheck? | LanceK | VENUE Live Sound Systems | 0 | 03-16-2014 06:39 PM |
Lost Virtual Soundcheck Connection | Rocky Presley | VENUE Live Sound Systems | 3 | 07-13-2013 04:53 PM |
Advice on PC for Virtual Soundcheck | Scott Fahy | VENUE Live Sound Systems | 1 | 01-06-2011 04:19 AM |
SC48 Virtual soundcheck | Sidhu | VENUE Live Sound Systems | 2 | 04-22-2010 12:43 PM |
Video into PT for Virtual Soundcheck? | SimonInAustralia | VENUE Live Sound Systems | 11 | 03-26-2010 05:17 PM |
