What in the word is going on ?????????????????????
Before i blow my brains out please some one try and help me!!!!!!!!!!!!!
setup is mac g5 dua2.0 1.5 gig of ram running os10.4.8 (ha ha )and pt 6.9.2 prior to this i was runnig pt 6.9 and panther uptaded to os tiger approx one week ago hence pt 6.9.2 every thing was fine and dandy till to day when i sparked up pt and got 1500 errors cant do [bleep] because date and time are incorrect spent three hours trying to correct time and date (every time i changed it would revert to original settings) finally managed to change it (hoo ray)Now every thing is Fuc#@D When i go to the Apple i have two of ever thing two restarts two shut downs two log outs two of every thing re installed os starting at 10.3.4 all the way up to os10.4.8 same [bleep] what in the world is going on ???????????????????????????????????? If i cud play the Bango thats what i would be doing right now!!!!!!!!!!!!!!!!!! Protools and Macintosh [bleep]#@G suck what ever happened to macking music ?????????? Any way this pistol is loaded and im going to do it!!!!!! Help Help Help Help Help Help Thanks Shaun |
Re: What in the word is going on ?????????????????
Any one?????????????????
Rail where are you in my our of need Seems you are the only one that knows whats up !!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
Any one???:??
Looks like a serious disk corruption issue to me. Do you have a bootable backup?
What happens when you boot from an install CD/DVD? |
Re: What in the word is going on ?????????????????????
Have you run DiskWarrior or Disk Utility on your system drive?
Rail
Hi Shaun.
Sorry to hear about your problem. I also upgaded from OSX 10.4.1 to 10.4.8 months ago and PT 6.9.2 would not load. According to what I saw then and also just a few minutes ago in the compatability section of this site, 6.9.2 is "officially supported" with 10.4.1 and 10.4.2. I suspect that this means that all subsequent OSX versions may not work. We are now running 10.4.4 with 6.9.2 very smoothly. I hope you can easily retrograde OS or upgrade PT to version 7 smoothly. I hope I've shed light... Mark |
Upon getting a cursor prompt, type fsck -fy (if I remember correctly.... There will be a blurb of text just above the cursor where you are typing telling you exactly what to type. Repeat the fsck command until the disk comes back clean. then type reboot. Search the apple site for fsck to get a little more info on what procedure you are starting by invoking the command. That way you can decide if it suits the problems you are having. It sounds to me like it should help, and it would be my first course of action. But since I'm not sitting in front of your machine I don't know for sure. Research the command before committing your entire system to it to make certain its applicable to your errors. Cheers!
Brad McIlvaine Sr. Mixer/Designer Henninger Media Services Washington, DC 20036 |
The DUC Word of the Day | spicemix | General Discussion | 23 | 01-10-2010 10:02 PM |
Any Word on PT 7.3 Yet?!? | relaxo | Pro Tools TDM Systems (Mac) | 7 | 10-09-2006 08:32 AM |
Word 1x vs. Word 256x | bennychico11 | Tips & Tricks | 2 | 12-29-2005 07:26 AM |
any word on? | astrorock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-30-2005 05:16 PM |
Any word on PT LE 5.1? | yavuzj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-08-2001 06:54 AM |
