Auth issue
My I-lok (A) I have MPTK and have been exporting mp3 as part of this bundle for quite a while other I-lok (B) I was given an I-Lok with a bunch of plugs on it that were NFR and had an expire date. I knew this was coming, so haven't been using any of these plugs except the MP3 option. The MP3 license just expired on I-lok (B) And now I have no MP3 export option. How do I go about linking this back to my I-Lok (A)? I look forward to your response I haven't listed my gear here as it is not a performance issue. Cheers and thanks in advance Bugly |
Re: Auth issue
Plug in I-lok A and your MPTK will be authorized. It's that easy. You can use more than one I-Lok at a time. Eventually you may be forced to do so. The folks over in the TDM section have been complaining about the Waves Mercury Bundle taking up almost a whole I-lok. So they are having to use two. Also, if you have an old MPTK like I did, the MP3 option was not on my I-lok. It was just a code on card. I emailed support and they updated it for me so now it's on my I-lok. Good luck.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
Re: Auth issue
Thanks for your reply @ndy
Although I have already tried that. and Yeah, I have been using two iloks for the past few months Unfortunately the MP3 option is not seeing the auth on my ilok (A) hmmm, maybe my Mp3 option was originally authed with a serial number too. This would explain the fact that the Auth is not on my I-lok (A) Needless to say, your thoughts/post were helpful Thanks Bugly |
PT v7.4 with v8 auth? | SATP | Tips & Tricks | 2 | 02-17-2010 04:56 PM |
M-Powered 8 -> LE 8 Auth? | sleazedc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-30-2009 03:06 PM |
ilok auth backwards compatibile - PT7.3 auth run 7.2? | Barnaby Bristol | Post - Surround - Video | 2 | 06-20-2007 09:30 AM |
L3 auth...How ? | Aquarius | Pro Tools TDM Systems (Mac) | 3 | 08-13-2004 10:27 AM |
