Old 03-29-2024, 02:29 AM
jpb1904 jpb1904 is offline
Default X-Touch controller and automation
My gear is a Windows-11 PC, Pro Tools, latest version and a Behringer X-Touch DAW controller. Connection is USB, HUI protocol.
When I want to do some automation on a track, I select a track and then hit on the controller the automation buttons, Latch, Write, etc. But nothing happens, the lights of the buttons flash up, but they do not stay lit. (=not ok)
But when I activate the automation setting in PT (Write, Latch etc) and play the track, then I can automate with my fader. And this is recorded and can be used. (=ok)
When automation is applied anyway and I play the track, then the faders of my controller follow the automation. (=ok)
So, my question is, is this normal behavior, or am I missing something?
Old 03-29-2024, 12:45 PM
Default Re: X-Touch controller and automation
When I want to do some automation on a track, I select a track and then hit on the controller the automation buttons, Latch, Write, etc. But nothing happens, the lights of the buttons flash up, but they do not stay lit. (=not ok) Are you selecting the track on the screen, or selecting the track on the controller first(I believe this is required)
Keep in mind that HUI is a somewhat limited protocol and it might not be able to do what you are trying for. I would check some youtube videos to see if another user shows the proper steps
Does touch automation work for MIDI Michael Carnes Virtual Instruments 2 06-22-2020 03:31 PM
set automation to off/touch (shortcut) Sir Hannes Getting Started 11 03-31-2018 01:10 PM
New Pro Tools Touch controller i'm working on smfelton General Discussion 101 12-13-2015 08:10 AM
C24 Touch Automation Bug autopilot ICON & C|24 0 04-10-2005 08:29 PM
II: Does anybody use a touch screen as controller? Kenny Gioia Pro Tools TDM Systems (Mac) 1 01-07-2002 12:24 AM
