Old 03-28-2024, 04:16 PM
BScout BScout is offline
Default Re: Keyboard Maestro functionality is broken with PT 2024
Originally Posted by Brettster View Post
There is no in-built shortcut for the "Delete" sub function under the Fades menu. That's what I've been using Keyboard Maestro for and would prefer to keep it that way.
Apple (System preferences > Keyboard > Keyboard Shortcuts > App Shortcuts) can assign shortcuts for submenus of an Application. These are the same hooks that Keyboard Maestro is engaging with.
And in Pro Tools, it can have shortcuts to delete fades.
But to each their own.
Old 03-28-2024, 06:11 PM
Brettster Brettster is offline
I've now set it within Pro Tools, but this is still a weird issue. Other sub commands do work, but for some reason that one will not work with KM, I had trouble getting it to work with anything. I prefer KM because it syncs with all of my systems without me having to think about it.
Old 03-28-2024, 06:21 PM
audiolex1 audiolex1 is offline
Cargo Cult said that Pro Tools is moving away from API, so I wonder if KM is using API and that is why it isn't working.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 03-30-2024, 03:15 PM
1m1 1m1 is offline
I'm doing more work with Pro Tools and KM today, and it is broken again. I tried the prescribed fix again, twice, and it doesn't help any longer. Not sure what else to try at this point.
Old 04-06-2024, 02:33 AM
Felix Rost Felix Rost is offline
Why API? KM is using Accessibility for all the UI interaction. API is referring to third-party access, like Spot API etc, which is going to be with the new scripting engine, which has nothing to do with that. At least at this point.
http://felixrost.de
  #16
Old 04-06-2024, 08:29 AM
FWIW all my KM commands continue to work without issue on 2024.3 on two separate recently upgraded machines, including a "Delete Fades" macro. Studio machines are on Ventura.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
  #17
Old 04-06-2024, 09:37 AM
JingleDjango JingleDjango is offline
I also continue to use KM without issue.
macOS 12.5.1
PT 2024.3
  #18
Old 04-06-2024, 01:46 PM
1m1 1m1 is offline
Just to clarify, my issues began when I updated to Sonoma. I have found workarounds for all of the issues so far.
  #19
Old 04-11-2024, 12:33 PM
1m1 1m1 is offline
I haven't installed yet, but today's 2024.3.1 release is supposed to fix these issues according to the bug fixes Knowledge Base:
"Issue with Apple script accessing menus on macOS Sonoma is now fixed (PT-317403)
Keyboard Maestro functions on macOS Sonoma (PT-312684)"
  #20
Old 04-11-2024, 04:24 PM
aals aals is offline
I just tested some random menus (among those that didn't work in Sonoma) and it seems to work
Keyboard Maestro - how's it help you? bolooki Pro Tools 2019 6 04-18-2020 02:07 AM
Keyboard Maestro Help TrentWilliams Tips & Tricks 1 12-08-2015 11:13 AM
Keyboard Maestro Trouble TrentWilliams General Discussion 0 12-08-2015 03:40 AM
Keyboard Maestro and PT 11 blankpro General Discussion 0 12-18-2014 08:20 AM
Quickeys or Keyboard Maestro or ? BMann Tips & Tricks 7 08-26-2010 08:17 PM
