Old 01-27-2008, 08:38 AM
manyrains manyrains is offline
Default no pdf guides
I just tried looking for the the reference guide and found that I have none of the pdf guides. I recently upgraded from 7.1 to 7.1.1, copied 7.1.1 to disk and have used that a coupole of times recently when doing a clean install while dealing with another issue. I have always been doing this guided by tech support as I get pretty confused with this stuff. I'm guessing that the pfs guides got lost/not reinstalled somewhere in this process.
Can someone tell me how to get those back?
By the way, the very basic question I was looking for is how do you delete a session? I haven't found this metiuooned in any of the books I have...
Thanks
www.jimsavage.net
www.manyrainsmedia.com
Mac Pro Late 2013, 3.7, 12GB, Apollo Twin, PT12, ADL 600, UA 2-1176, Mojave MA-200
Old 01-27-2008, 08:50 AM
Phil Ogden Phil Ogden is offline
Default Re: no pdf guides
PT7.0-7.1.1 Documentation Installer for Mac OSX
Log in and scroll to page 2
To delete a session, simply drag the folder to the trash. **Care** - make sure that the audio files folder doesn't contain anything used in another session. Sometimes PT just links to the media location.
http://www.myspace.com/philogg
Old 01-27-2008, 08:57 AM
Thanks Phil. I had a hunch there could be issues as you advised about re files being shared etc. That's why I wanted to wait. As I said, I'm still getting used to how/where/why files are stored various places. How do I know if a file is being used in another session? What would be an example?
www.jimsavage.net
Old 01-27-2008, 09:31 AM
If you suspect something might have been used in another session (samples are a common example),
1. Open that session and select 'show full path' in the regions bin (right of edit window). This will tell you where the audio resides.
2. If you see anything linked from the session you're about to delete, consolidate that region and a new file will be created.
3. Clear/Remove the redundant (linked) region from this session and you should be good to go.
Old 01-27-2008, 09:42 AM
Thanks!
www.jimsavage.net
Updated guides? Jesper G 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-09-2008 01:11 PM
Where are all guides? maroc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-21-2006 09:54 PM
Reference Guides for PT 6.7 Alwaysfinlost 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-26-2006 11:44 AM
Just upgraded to 7.0 but no help guides Pont68 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-16-2006 03:01 PM
Guides For EQ?? Orange Worker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 07-13-2004 04:17 AM
