  #21
Old 12-08-2017, 10:42 AM
philper philper is offline
Default Re: AAF from Premiere works! (sorta)
I asked because by now all my projects that were started on FCP7 have been completed, and none of my clients are using it anymore. Most went to Premiere, a few went to FCX, unfortunately.
  #22
Old 10-21-2018, 03:23 AM
Paph Paph is offline
During searching try to check "Find By Name" and also check "Match Format" ONLY. It often works. I think this bug happened because the information about duration of files is incorrect. So when "Match Duration" box is unchecked Pro Tools will able to find all missed files.
  #23
Old 10-21-2018, 03:38 AM
Originally Posted by Nathan W. View Post
For the first time in my career we actually got an AAF to work with Protools with one caveat: all the audio clip names are totally messed up and I have no idea why. It looks like it's taking the video clip names and not the original audio names. Anyone know anything about this? Trying to get original clip names in the AAF files.
Nathan
  #24
Old 11-21-2018, 07:45 AM
seanmccoy seanmccoy is offline
Hey, all. I've been going back and forth with an editor doing AAF exports for the first time. Of course, he had nested everything, but after we got that sorted he was eventually able to send me an AAF that did contain all the proper clips (file names were intact, BTW). BUT, while his added music tracks are rock solid, the dialogue tracks move in and out of sync. It's not drift, but different sections will be off by a specific amount, always late. I ran into this once before, years ago, but can't remember what the cause was. I suspect it has something to do with how he's implementing ramp-ups and crossfades, but can't be sure. Does this symptom sound familiar to anybody?
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
  #25
Old 11-21-2018, 10:58 AM
Non-48k AIFF or wav audio clips? Are they doing clip fades or fades using keyframes?
  #26
Old 11-21-2018, 12:20 PM
All the dialogue files have video file extensions, so it's probably safe to assume they originated at 48. All the fades show up as Pro Tools fades. There is some static clip gain, but no volume automation. I'm not sure what that means in terms of the process within Premiere.
  #27
Old 11-22-2018, 05:18 AM
trevora trevora is offline
Did they modify frame rates in PP?
  #28
Old 11-22-2018, 08:31 AM
Unknown on all, but thanks for the leads. I'll ask him.
  #29
Old 11-22-2018, 09:37 AM
And do they have any sort of playback speed processed running, like slowmo clips etc, or are using any Audiosuite etc plugins on the audio?
  #30
Old 11-23-2018, 08:40 AM
Definitely some slow-mo segments in the video. Can slow-mo in PP cause audio displacement, even if it plays back at the proper speed?
HTML code is On
Need some mic advice *sorta off-topic* xbook Tips & Tricks 2 12-13-2006 06:54 PM
Startup problem (sorta) senectavit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-17-2006 04:01 PM
Did they sorta break the trimmer? remainanon Pro Tools TDM Systems (Mac) 0 08-31-2005 10:25 PM
sorta OT: Can't install OSX on Volume HELP!!!!!!! KingFish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-09-2005 12:22 AM
Sorta OT: Problems with Roland jx-305 timmygrimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-17-2002 08:38 AM
