tons of questions for you all
I posted a message the other day about Direct Boxes, and I'm back with more questions. What is a "High Pass Filter" (that is measured in Hz?? and....What exactly does balanced (XLR) throu-outputs mean compared to standard?? (or ..is that standard and i am just dumb and don't know any better?) all replies are greatly appreciated, and any other info for equipment dumb people.
P.S. ...What is an Optical Splitter??? |
Re: tons of questions for you all
A HPF is basically an EQ filter that allows High Frequencies (above an assigned frequency that is measured in Hz) to Pass. Also known as a low cut filter or a rumble filter depending on the cutoff frequency.
Balanced XLR's are not standerd. They are normal and recommended, but sometimes can be unbalanced. Hope this Helps, MasterJ [img]images/icons/smile.gif[/img] |
high pass filter will allow high sounds through and stop low sounds. The pitch of sound is measured in Hz and KiloHerz (thousend Hz). An Example: you have a singer and on the background there is some rumble. When you apply the highpassfilter and adjust the settings right, you can eliminate the rumble.
Balanced connections have 3 wires (ground, hot and cold) wich will help to reject interference picked up in the cable. You can connect balanced in/outs with an xlr or trs connector. The XLR is rather large and has 3 pins (or holes) inside it. TRS stands for tip, ring, sleeve, and is just a standard 1/4" headphone jack. for balanced operation it is wired like this: t=hot, r=cold, s=ground. It is possible to mingle balanced and unbalanced connections or cables, it is not recommended.....balanced is better! Hope this helps a bit
What's that? - That's the machine that goes "pling". Bastiaan |
that does help, thanks a lot....I have a million of questions for people on here, and you guys are guru's, I love it..always so precise and helpful, thanks a lot...keep your eyes pealed for more Q/A's. thanks..
What is an Optical Splitter? |
8.0.3 = Tons of Static | imloggedin | Pro Tools TDM Systems (Win) | 44 | 02-06-2010 01:34 PM |
Plug-Ins using tons of CPU | RichrdC | Pro Tools M-Powered (Win) | 0 | 08-27-2009 04:26 PM |
Amplitube Using Tons of CPU | RichrdC | Pro Tools M-Powered (Win) | 11 | 08-16-2009 07:53 PM |
Tons and Tons of Outboard Gear | TommyComa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 06-18-2007 11:43 AM |
6.9 using up TONS of CPU | Produce_Dept | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 04-25-2005 06:48 AM |
