  #21
Old 02-13-2020, 02:16 PM
dg27's Avatar
dg27 dg27 is offline
Default Re: Moving from 12.8.3 to 2019.12
Sorry, got confused as this topic is on another thread also
No problem: Appreciate your guidance.
At least now I'm pretty confident that since the MBox driver works with Win 10, I don't have to replace my interface immediately.
Thanks.
  #22
Old 02-13-2020, 03:23 PM
dg27's Avatar
For the benefit of anyone else who may be wondering:
Avid Introduce Windows 10 Compatibility To 3rd Generation Mboxes
https://www.pro-tools-pc.com/avid-windows-10-mboxes/
  #23
Old 02-13-2020, 03:28 PM
JFreak JFreak is online now
Isn't that the same information as in here?
  #24
Old 02-13-2020, 06:18 PM
dg27's Avatar
Yes. But I thought it was a good write-up.
  #25
Old 02-16-2020, 08:26 AM
dg27's Avatar
So I'm about to close Win 7 for the last time, install Win 10, then install PT 2019.12 tomorrow.
I backed up my Pro Tools folder that's in the Documents folder, which has the gazillion plugin presets I've created over the years.
Is there anything else related to PT that I should back up, such as I/O settings?
I also saved my Trasher backups folder. Will I be able to insert this in my Trasher folder once I'm on Win 10/PT 2019,12 and restore using Trasher?
  #26
Old 02-16-2020, 08:32 AM
IO settings are usually easier/faster to re-create than backup and restore
  #27
Old 02-16-2020, 08:36 AM
dg27's Avatar
Thanks, JFreak. I'll just do that.
What about restoring my prefs using Trasher? Will that work if I insert the old Trasher folder in my new install and run Trasher?
  #28
Old 02-16-2020, 08:37 AM
Don't know about Trasher, but prefs file is just a file you can backup/restore
  #29
Old 02-16-2020, 08:42 AM
dg27's Avatar
Thanks.
I think I found it in User/AppData/Roaming/Pro Tools.
  #30
Old 02-16-2020, 08:44 AM
I'm a Mac guy, you need to google it
Workspace Borked 2019.10 and 2019.12 KMcK Pro Tools 2019 0 01-17-2020 02:09 PM
2019 iMac vs 2019 Mac Pro Peterjk Pro Tools HDX & HD Native Systems (Mac) 7 01-14-2020 12:23 AM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 08:30 AM
