Opinions on converting an old Server to Pro Tools machine
I'll be picking up a 2U rack server on Saturday and converting it for Audio production. Even if it ends up not working out for Audio stuffs...for the price I am paying, I can't pass it up. I'll still have plenty of fun tinkering with the machine. Basic specs below:
2U Rackable half depth system 1x Tyan S7012 Motherboard (SSI EEB Form Factor) 2x Intel Xeon X5650's (six cores at 2.66Ghz) 72GB DDR3 ECC Reg Ram (4GB Dimms) 2x SATA 1TB HDD's (Six SATA ports and two SAS's) - will likely be swapped out Onboard ICH10R Raid Controller Onboard Quad 1Gigabit Ethernet ports Onboard Dedicated IPMI 2.0 450W PSU - Will likely be upgraded Five PCIe x8 (Four usable slots) The man issues I expect to face are in implementation of my RME RayDAT card (as it is not low profile) but I should be able to compensate with a riser(flex cable). Low Wattage PSU (that I can't find recommended replacements for online and will have to wait until I look at the thing before finding a suitable replacement). And, the lack of GPU expandability (which I will likely use a 16x female --> 8x male PCIe riser - Flex cable to accommodate). I only care about adding a GPU for use of dual monitors since the onboard graphics won't allow for that and I refuse to mix on a single monitor. I plan to pick up 3 or 4 like branded HDDs (possibly raptors) to run in RAID 5 with a SSD for the OS (Windows 7 x64 pro). Will mainly be running Pro Tools 11 (non HD). I don't intend to use this machine for gaming or media. I am slightly concerned with airflow due to the size of the case and the fact that it will be in my rack with my other gear. This is my first real journey into the world of server machines so any advice would be much appreciated. |
Re: Opinions on converting an old Server to Pro Tools machine
a real server case is going to be LOUD do to fans/air movement
also most servers have 2 or 3 PSUs I would get SSDs for audio and system drives and do a RAID 5 with Green or Red drives for backup
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Just don't record to those green drives. You might solve a few issues by moving everything into a 4u case(the RME would fit and you would have more space for drives). In any case, it could be a fun experiment. I would hold off on drives until you find out if its compatible with Pro Tools.
Converting Mac Pro Intel Machine into PCIe Chassis? | Paulthe3rd | Pro Tools TDM Systems (Mac) | 2 | 11-21-2013 10:24 AM |
500 Internal Server Error We're sorry but the web server encountered an unexpected c | DrumEatDrum | Getting Started | 10 | 07-09-2013 11:47 AM |
Opinions on Slate virtual tape machine? | crizdee | General Discussion | 7 | 02-10-2013 02:15 PM |
Files transfered server-server relay still downloaded from remote server | Phill Barrett | Aspera DigiDelivery | 1 | 03-19-2010 01:58 AM |
Okay. So Why Aren't We Using Server 2003 or Server 2008 Again? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-26-2009 09:26 PM |
