Please read and give some feedback on this report
I am having some problems with the buffer wanting to stop. I'm running PT8 with the new update. I have done a sandra report and it is below this post here.
Please tell me if there is anything special I could do to the computer or if I need a new one. I have done all the xp tweaks as far as turning off visual effects and what not.. Thank you here is the sandra report now. SiSoftware Sandra System Host Name : IZZY-444BE9F595 User : Izzy White Workgroup : BAKWUDZ Processor Model : AMD Athlon(tm) 64 X2 Dual-Core Processor TK-57 Speed : 1.90GHz Model Number : 3390 Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Low Power, Dual-Core Internal Data Cache : 2x 64kB, Synchronous, Write-Back, 2-way, 64 byte line size L2 On-board Cache : 2x 256kB, ECC, Synchronous, Write-Back, 16-way, 64 byte line size System System : Acer Extensa 4420 Platform Compliance : AMD LIVE! Mainboard : Acer Extensa 4420 Bus(es) : PCI PCIe IMB CardBus USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : 1 Processor(s) Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Phoenix Technologies LTD 255.255 Total Memory : 1.87GB DDR2 Chipset 1 Model : Acer ??? (7910) Front Side Bus Speed : 1x 199MHz (199MHz) Chipset 2 Model : AMD Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 796MHz (1.59GHz) Total Memory : 2GB DDR2 Memory Bus Speed : 2x 316MHz (632MHz) Video System Monitor/Panel : Default Monitor Monitor/Panel : Generic Television Monitor/Panel : Plug and Play Monitor Adapter : ATI Radeon X1200 Series Physical Storage Devices Hitachi HTS542516K9SA00 160GB (SATA150, NCQ, 7MB Cache) : 149.05GB (C:) Optiarc DVD RW AD-7560A (ATAPI33, 24x CD-R, 24x CD-W, 3x DVD-R, 3x DVD-W, 2MB Cache) : N/A (D:) Disk : N/A (E:) Logical Storage Devices Hard Disk (C:) : 149.04GB (80.43GB, 54% Free Space) (NTFS) @ Hitachi HTS542516K9SA00 160GB (SATA150, NCQ, 7MB Cache) CD-ROM/DVD (D:) : N/A @ Optiarc DVD RW AD-7560A (ATAPI33, 24x CD-R, 24x CD-W, 3x DVD-R, 3x DVD-W, 2MB Cache) CD-ROM/DVD (E:) : N/A @ Disk Peripherals USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Generic CardBus Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Synaptics PS/2 Port TouchPad Printers and Faxes Model : Send To OneNote 2007 Model : Microsoft XPS Document Writer Model : HP Photosmart C6100 series Power Management Mains (AC) Line Status : On-Line Battery No 1 : 97% Operating System(s) Windows System : Microsoft Windows XP (2002) Professional Media Center 5.01.2600 (Service Pack 3) Platform Compliance : Win32 x86 Network Services Adapter : Dell Wireless 1395 WLAN Mini-Card |
Re: Please read and give some feedback on this report
What exactly are you having problems with? Buffer issues as in its asking you to set the buffer size lower or higher?
Pro tools HD 9 - HD3 setup w/96 IO AMD 3.81GHZ Phenom II X6 CPU - 8GB Ram - Win7 64-bit Focusrite Voicemaster Pro Presonus StudioLive 16 Channel Mixer Digimax D8 8-Channel Preamp Command 8 Vocal and Instrument Recording/Live PTHD Mixing |
It stops at random times and ask me to set my buffer higher. But the higher I got the more delay I have in vocals if that makes sense.
You need a secondary hard drive for Pro Tools sessions...
You'll also need to disable your wireless LAN while using PT. |
I'm sorry I didn't add that in there... I do have one just for pro tools sessions that I use. It's a 7200rpm usb drive. I have the acer extensa 4420 laptop with the mbox mini 2.
I have 2 gb's of ram should I go up? I was just looking and they said I can go to 4 gb's but something about windows would only see 3.25 so they recommend a 2gb + 1gb = 3gb configuration. Do you guys think this would help going up 1 gb on the ram? |
USB drives are not the answer.
From the General Troubleshooting thread: Quote:
I'll give that a try then. I have a firewire port on here and i'll try out a firewire drive because I have one but it's full but i'll try it out and see if I still get the buffer errors.
Thanks guys |
Your firewire chipset may not be comaptible. From the above quote from JMS40:
"Firewire drives must have the Oxford 911 (FW400 port), Oxford 912 (FW400 & FW800 ports) or Oxford 924 (FW800 ports) Bridge chip." Cheers,
Here's a great low-cost alternative. The Bytec ME720 external firewire case HAS the Oxford 911 chipset, and I just bought my second one from www.bteccstore.com for $35.00 to my door. Stick in any 7200 rpm IDE drive and go to work.
PLEASE give your feedback on the PC I'm buying | Zarabozo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 07-18-2010 12:50 PM |
Can someone give me some M-Box feedback? | Deirdre B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-24-2003 10:24 PM |
New Mix, PLease Listen and Give Feedback! | jdevenny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 02-26-2003 08:47 PM |
New Mix, Please Listen and Give Feedback! | jdevenny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 02-21-2003 12:13 AM |
Give me some feedback (critique) | chucknkd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-07-2002 01:53 AM |
