Old 02-01-2004, 09:48 AM
SNAZ SNAZ is offline
Default Error 5000 while verifying authorization
I got this message just finishing setup with new G5 dual 1.8 with 10.3.2, PT6.2.2 HD, the first time I go into Protools, just writed the serial and first time to open appears loading plug ins, I put the autorizer card on the key but still on same message, any suggestion?
Old 02-01-2004, 10:44 AM
Default Re: Error 5000 while verifying authorization
We need more info, such as:
1. How many admin level usernames do you have for your OS X install?
2. Which plugin is generating the error?
This will help the DUC help you solve your problem.
Old 02-01-2004, 11:20 AM
Jan Folkson Jan Folkson is offline
Every time that I've seen this error it's been caused by a permission problem. Make sure that all of your drives and partitions have the correct read/write permissions.
HTH.
- Jan Folkson
www.janfolkson.com
Old 02-01-2004, 11:17 PM
is a new installation, only one user, plug ins are the Focusrite bundle for a HD1 system
Old 02-02-2004, 07:50 AM
Check all your drives and partitions by 'getting info' and make sure that you have read/write permissions. This can be a problem even on new installations.
- Jan Folkson
www.janfolkson.com
PRO TOOLS LE 8 Eroor #-5000 when verifying your authorization. jupzchris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 11-04-2010 06:06 PM
Error #-5000 while verifying your authorization. (Air Plugins) jiveman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-03-2010 12:19 PM
More fustration!! Error 5000 while verifying authorization carpmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-26-2009 09:21 AM
Help! Error #-5000 while verifying your authoriza b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-13-2007 06:46 PM
Error 5000 while verifying authorization Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-01-2003 06:54 AM
