Old 01-02-2019, 03:34 PM
ihate100bees ihate100bees is offline
Default 2018.7 vs. Your Disk cache size for Playback?
Just curious on what others select as their disk cache size, in Setup-Playback Engine-Disk Playback in 2018.7 (Win 10 and 32gb ram)? I don't usually change this unless I will be mixing with a lot of plugins and tracks. but for all around general purposes... what's yours set to?
thanks!
Old 01-02-2019, 03:52 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: 2018.7 vs. Your Disk cache size for Playback?
Depends on the available RAM but i have my desktop set to 6 and the laptops set to 2
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 01-02-2019, 03:56 PM
With 32GB of RAM.
Old 01-02-2019, 04:20 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
I usually leave it at 4GB unless the session is of high track count and their 32bits / 96k or higher.
Even with that usually after stripe silence and deleting unused audio files 4 GBs is more than enough for music production for what I do in a 3 1/2 to 4 minute song.
Sent from my SM-N950U using Tapatalk
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 01-02-2019, 05:23 PM
BScout BScout is offline
Disk cache is to take the load off of the hard disks/storage controller (ie audio file playback) by preloading them into a RAM "disk". I attempt to keep it so that my full sessions can be loaded into that RAM disk (so all the audio files in use are there and don't have to be pulled off of the hard disks after I open the session.)
I have 64GB RAM and 48GB goes to the disk cache at all times.
Old 01-02-2019, 06:08 PM
I use 4GB(tried 10GB and noticed no change at all). Running a total of 64GB between dual 6-core cpu's(and pretty much never a session longer than 5 minutes).
Old 01-02-2019, 06:12 PM
StillHollow StillHollow is offline
3 gigs hasn’t failed me yet on mostly projects 40 tracks and below.
Old 01-02-2019, 06:39 PM
AlexLakis AlexLakis is offline
Seems any size will do. And don't worry about running out of disk cache in the middle of a take; I've done tests and disk cache maxing out did not disrupt recording.
Disk Playback Cache Size? dg27 Pro Tools 12 18 06-07-2019 08:15 AM
PT 2018.7 don't remember my playback engine buffer size Franklyn Pro Tools 2018 0 08-07-2018 01:28 AM
Could not allocate memory for the disk cache. Try lowering your disk buffer.. slim_shady Pro Tools 10 15 05-09-2017 05:20 PM
PT10's Disk Cache or RAM Disk. Why not use the same concept for VI memory space? sunburst79 General Discussion 6 09-15-2011 11:28 AM
