  #21
Old 09-02-2009, 06:54 AM
masterplan masterplan is offline
Default Re: Huge adc bug!??
Yes it would be great to know that Digi know this is quite a big issue for people making music.
Less noticeable with low latency plugins but still a HUGE issue when you cant trust what you just recorded!
Come on Digi!!!
Get of the playground that Apple and Steinberg are dominating already and get back to the pro-world where things work!!
P
  #22
Old 09-02-2009, 06:57 AM
steins steins is offline
Originally Posted by muhis1 View Post
1. Create an audio track!!
2. Create an instrument track.
3. Put 3 Maxim on the !!!!!AUDIO!!!!! track.
4. Insert BOOM on the instrument track.
5. Create a click track....so you have something to compare with!
6. Record something by playing on BOOM from your keyboard.
6.5....DO NOT QUANTIZE!!
7. Everything you just recorded WILL END UP LATE!!
Please DIGI this is not something a PRO program should do!!
This means that everything you record with audio instruments will be wrong!! And even if it's just a matter of like 10 samples it's still unacceptable!!!
DIGIDESIGN!!!!!!....are you listening!!!??
Create an audio track. Create a software instrument track. Insert a latency demanding plugin like Maxim (insert 2 or 3 Maxim to really experience the bug) on the audio channel. Now open, for instance, boom on the software instrument track. When you now play boom you'll have latency....right! But when you press rec the ADC is bypassed on that channel.
Now try to record a simple bd/sd thing from your keyboard together with a click.
When I does that!!.....what I hear when I play....is NOOOOT what comes down on the BOOM track. Everything I play is delayed when recorded.....by the amount of latency the Maxims are creating.
Thank you so much digi!....do I have to go back to version 7 or is there a major fault on my new Intel mac with pro tools accel 2??
Can someone help me with this!?
/Kermit
Tried this on my system (Intel Dual-Core, HD3 Accel), everything plays in sync, in fact when I flip the phase on the audio channel, it nulls perfectly with the Boom track.
Did you remember to assign an audio input to the Instrument track.....?
Stein Tore
  #23
Old 09-02-2009, 07:11 AM
woodsdenis woodsdenis is offline
Stein Tore
This is not about comparing an audio track with a vi. The audio track is just there to insert a high latency plugin. Nothing else.
Record Boom on the instrument track referencing the click plugin
Play back Boom and see if it is the same as what you played.
Both Muhis and I are seeing the midi recorded as way late. Its as if ADC is compensating incorrectly.
The reason it is so obvious is that there are hi latency plugins in the session
Try this and see
thanks
Denis
Mac Pro 3.3 hexacore
24 gb RAM
Lion
PT 10 HD Native
  #24
Old 09-02-2009, 07:37 AM
Both Muhis and I are seeing the midi recorded as way late. Its as if ADC compensating incorrectly.
Try this and see
thanks
I see. Same thing happens here. Hmmm. Not good. According to the manual (page 865), Pro Tools are supposed to shift back the Midi after a record pass. Surprise: It doesn't.
I'm on 8.0cs3
Stein Tore
  #25
Old 09-02-2009, 07:40 AM
I'm on 8.0cs3
Stein Tore
Thanks Stein
This goes back the cs3 at least
DTS where are you
Denis
24 gb RAM
Lion
PT 10 HD Native
  #26
Old 09-02-2009, 07:56 AM
Thanks Stein
DTS where are you
I don't know if this is a work-around or a feature, but if you enable "Always Compensate" mode on the instrument track by Command-Control-clicking (Mac) the track compensation indicator before recording, the Midi lines up. You have to disable it during playback for compensation to work.
Stein Tore
  #27
Old 09-02-2009, 08:24 AM
Stein Tore
You are absolutely correct Stein but obviously this is not how it should work.
Denis
24 gb RAM
Lion
PT 10 HD Native
  #28
Old 09-02-2009, 08:52 AM
Dizzi45Z Dizzi45Z is offline
I have read posts about this before. This issue has been around for awhile. I need to go back and check, but I have figured that another work around is to turn off Delay compensation when you record midi. Then it all seems to work.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
  #29
Old 09-02-2009, 08:58 AM
muhis1 muhis1 is offline
Muhis
Did it just show up in PT8.0.1 or in all versions of PT8 and subsequent cs updates
Well.....at least in 8 with cs 3 and in 8.0.1.
I think I installed the cs3 fix when I first installed pt8.
I'm pretty new in the "pro tools software family". I ran logic
with pt hardware before.
But I can't imagine that the problem came with cs3!
/Kermit
Mac Pro Nehalem 2,66 with 12 GB ram, Pro Tools 8.1, HD2 Accel, 192 I/O with 2 882s, UAD 2 QUAD OMNI. OSX 10.6.4
  #30
Old 09-02-2009, 09:02 AM
Shure!...but everything else will sound like ???? then.
New Mac Pro and HD2 HUGE PROBLEMS Dolly Pro Tools TDM Systems (Mac) 6 09-13-2010 02:12 PM
HUGE Problem with HD 8.0.4 maybe ADC??? smilerecord Pro Tools TDM Systems (Mac) 0 08-19-2010 08:35 AM
A Huge THANK-YOU RussUK Virtual Instruments 16 06-03-2009 08:00 PM
i have a huge problem!!! please help! moisesgalvan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-15-2007 04:51 PM
huge problems with 001 rhysw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-14-2004 06:51 PM
