Old 05-28-2012, 08:54 AM
Bantom Bantom is offline
Default Digi 002 Lost connection-Help Please!
I was working on a session just fine and all of a sudden a warning came up that my 002 had lost connection with PT. I closed down the session and rebooted my CPU and rebooted my 002 and I can't get pro tools to recognize it again. I have been reading about the power harness issue and i don't think it is that as all of the lights still light up and it says Digi 002 in the track windows as normal and I can hit buttons as normal and use the aux feed as normal, I just can't get it to see my session anymore. Any help would be great. I am in the middle of a big project (of course) and I really need my 002 back.
Old 05-29-2012, 10:19 AM
JazzyJ JazzyJ is offline
Default Re: Digi 002 Lost connection-Help Please!
Check cables and firewire ports.
If you have a different firewire buss (a different card etc) then try that.
You haven't put your spec down (as is suggested by the forum) so you limit your chances of help immediately.
Hardware & Software?????
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 05-29-2012, 01:41 PM
The Dougfather The Dougfather is offline
If your suffering from the power harness issue then you physically won't be able to load your sessions because you'll get 'Hardware not found' and theres where it will end.
The 002 may appear fully operational at a glance but it's the ability to establish the firewire connection that is the issue.
Defo check out cables and firewire ports, try another PC/Mac if you can.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 05-29-2012, 04:12 PM
You might also try reseating the harness connectors several times each(to scrape thru the oxidation that builds up on the pins). With the rack, there are 3 connections(and its really simple). With the mixer, there are 4 connections and its more involved due to the location of the PSU(bolted to the bottom pan) and the 4th connection which is sort of hidden under the firewire PCB.
Old 05-31-2012, 12:29 PM
jhamrick jhamrick is offline
On my 003 I once had this issue. During the launch of ProTools I held down the "N" key on the MAC keyboard and chose my interface when prompted to do so. Interface was recognized.
If a resource problem with that one session, open protools and choose new session, in the new session change resource settings to higher buffer. Close the new session and re-try opening the session that was having problems...
-Jesse
___________________________________________
Lost connection to Mix and Control musikrolf Artist Series 9 05-23-2012 07:34 AM
Lost connection Stig Eliassen ICON & C|24 8 03-13-2012 03:19 PM
Lost Connection w/ my 002R! kingfly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-13-2009 03:16 AM
Lost Connection 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-16-2006 12:09 AM
Digi 002 lost connection Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-19-2005 01:55 PM
